2017 4010 mule front diff popping
/ 2017 4010 mule front diff popping #1
dieselbeef
myakka city
bx2200..jd 2010 loader backhoe tractor
took it to the dealer.they said its normal due to diff gear ratios front to back and gave me a service bulletin that says only to use 4x4 when necessary..as if I can anticipate when im going to get stuck. and of what imploding in the diff as the gears are coming unmeshed of the little pieces and shavings going thru the diff brgs
not real happy about it..almost don't want it now..almost 10 grand for it makes so much noise I cant go to my stand in the morning
/ 2017 4010 mule front diff popping #2
Sounds if it will blow soon. The warning to use only when necessary means not to use on hard surface.
If the front diff. has a diff lock it may be engaging.
Tell dealer you want to try another one. If he does not attempt to help contact the manufacturer.
we did...they all did it. even had another customer in there picking one up had the same issue. I get the not on hard surface thng but crap man im in a muddy pasture..if it isn't going forward withut slipping the rears then im putting it in 4x4 and then itll start to pop every hundred yds or so. I even got the tsb from kaw on it from the dealer and they say that's normal....
poor setup I tell ya. and it rides like crap but it will be around a long time as it seems to e built really well...not a lot flashy flimsy look cool stuff on it
2004 Johnson 40hp 4-Stroke Outboard Boat Motor (A66738)
2004 Johnson 40hp...
WACKER NEUSON  LTN8 LIGHT PLANT (A67714)
WACKER NEUSON...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
2022 TYM T474 TRACTOR (A65057)
2022 TYM T474...
2001 Frieghtliner MT55 Chassis Step Van (A66736)
2001 Frieghtliner...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A65054)
(INOP) 2013 MACK...
