2016 RX6620 Powershuttle Initial Impressions
   / 2016 RX6620 Powershuttle Initial Impressions #1
Areeves08
Bolivar
Kioti RX6620 Powershuttle
I recently purchased a new 2016 RX6620 Powershuttle to replace a 2016 John Deere 3033R PowerReverser that just wasn't enough tractor. I thought I'd provide some of my initial thoughts for those that might be considering this model. I have spent many hours on my FIL's 2013 John Deere 5065E and will use that for some of the comparisons.
The Good
Some of what immediately struck me about the RX was the quietness of the engine and the smoothness of the transmission. Both are much more refined than the Tier3 5065E. The base 5065E is a bare bones utility tractor that stickered well above the RX, but had far less features. The self-leveling loader on the RX is amazing to operate vs the JD 553 loader. The speed could be improved, but I don't mind the more precise feel of the slower movements. The RX also has electronic 4WD and an electronically adjustable clutch. The PTO knob is convenient, but I must maintain at least 1500-1600 to keep the tractor from stalling with my MX8 rotary cutter. The ePTO and auto PTO are also nice features that the 5065E doesn't have. Don't forget to disengage the auto PTO if you don't need it, though, or you'll struggle to figure our why your implements aren't spinning (ask me how I know). A big plus is the 12F/12R transmission with a very tall 12th gear. We convoyed the 5065E and RX to a property this weekend and the RX left the JD in the dust. Attaching implements to the 3pt is also a plus for the RX. The combination of telescoping links and the rear rockshaft control lever makes hookup a breeze. Visibility is also considerably better on the RX. The JD has a long flat hood that is relatively level with a low seat position. The RX seems to position the driver higher while increasing the forward slope of the hood for greater visibility.
The Bad
It didn't take me long to notice how narrow the seat on the RX is. My JD 3033R rides like a Cadillac with a wide suspension seat and seat belt that is very comfortable. You can tell the RX seat is a budget suspension seat. It is narrow for my frame at 6'1" 195. While mowing a side hill, the seat belt constantly dug into my hip to the point I removed the belt and shoved the belt attachment to the rear. I can't stand being on the tractor without a seat belt, so this was really uncomfortable for me to have to unbelt. The dash lights also need some attention. While roading the tractor with the hazards flashing on an overcast day, I couldn't see the indicator lights at all. I repeatedly left the turn signal on because I couldn't see the blinking. Some of the other indicators were more visible. On a tractor this large, some sort of on-board storage would be nice. JD could fit a covered compartment on the fender of the 3033R, so I know there's enough space. I moved some piles of brush with the bucket and noticed the front hydraulic lines were susceptible to becoming entangled with branches. This could probably be fixed by use of a grapple, but that's down the road. The transmission could also use some adjustment. When mowing, if you were moving even slightly downhill and shifted to the opposite direction, the tractor would continue for as much as 10 to 15 feet before reversing direction. I started using the brakes when changing directions as well, but I think a different transmission setting would be beneficial.
As I put in more seat time, I'll continue to add my thoughts on the RX vs 5065E. I've ordered the canopy, additional SCV with float and the 7pin harness, so I should have comments on those items in the near future. Feel free to throw in your thoughts as well if you've had additional experience with the RX.
   / 2016 RX6620 Powershuttle Initial Impressions #2
I agree on the seat belt and seat itself. It was such pain I took my seat belt right out of the tractor. (I'm 5'10" 185) Let's be honest here, I work on much flatter land than most. I think you summed up the RX6620 really good. I do wish it had a tool box and would have loved a buddy seat.
It is my first tractor so lots of learning, but I am very happy with it.
After about 20hrs on the clock, I'm faced with my first warranty issue. The loader control sticks in the dump/curl curcuit. I pull the cover off the loader control mount to see if any debris was causing the lever to stick, but it was free and clear. The curl/dump functions still work, but the control lever will stick in either position rather than returning to the center position. It also causes the loader lock to be inoperable. I plan to swing by the Kioti dealer this week and see what they can do. On a positive note, the sunshade, additional SCV and 7-pin harness should be in this week.
   / 2016 RX6620 Powershuttle Initial Impressions #4
I also have a 2015 RX6620PS Cab and love it. I live in central Louisiana and have put this thing through everything I could find and had zero issues.
I agree on the seat, sitting in it for several hours is kinda a pain in the rear.
I am looking around for a 3-point backhoe that would work on the RX6620 with a cab. Any ideas to what would work?
Thanks,
PuJo
   / 2016 RX6620 Powershuttle Initial Impressions #5
Thanks,
PuJo
My dealer said I couldn't put a back hoe on mine - -- but, I seen a RX6620ps cab model with a Kioti back hoe on TBN. Can't remember which thread though.
It ended up being an easy fix on the loader control. The lock-out tab the sticks out the front became slightly bent and was pushing against one of the cables. I removed the lock-out lever to avoid any further issues. Pushing piles of brush have been no sweat and it's run a Woods BB840X and JD MX8 rotary cutters with ease.
   / 2016 RX6620 Powershuttle Initial Impressions #7
I was looks at the RX or the PX and decid on the PX. One of the benefits was a bigger seat. I wonder if you can exchange them and have an easier hookup and mounting experience.
   / 2016 RX6620 Powershuttle Initial Impressions #8
To PuJo: I've got a 2012 RX6010C I bought in 2014 with 200 hours on it. It came with a backhoe (Model KB2485) that I only played with for an hour but then took off and have never used again....its basically new. I don't think I really need it, and may sell the backhoe. Dealer (S & H Farm Supply) says it's a $9,000 attachment. I'd probably sell it for $4,000. However, I won't remove the heavy "subframe" that is installed to accomodate the hoe, so you'd have to price that. If you're interested, let me know and I'll get you my number. I'm in Springfield, MO.
   / 2016 RX6620 Powershuttle Initial Impressions #9
cat fever...... I've got a basically new backhoe that came with my RX6010C that I've never used. See my post below......if you are interested it is Model No. KB2485........sales literature says its an option with the RX6620.
   / 2016 RX6620 Powershuttle Initial Impressions #10
Thanks mulespb,
A BH is something I would like but not something I need. I only mentioned it because my dealer said the RX6620 could not have one. Maybe he meant the cab model. :confused3: I just remember seeing one with a BH.
John Deere Hay Spear (A56469)
John Deere Hay...
3410 (A47477)
3410 (A47477)
250ft Roll of Copper-Clad Aluminum Building Wire (A55852)
250ft Roll of...
2020 Nissan Altima Sedan (A55853)
2020 Nissan Altima...
2023 John Deere 8RX 370 Track Tractor (A53485)
2023 John Deere...
2020 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A55852)
2020 Ram 1500...
