2016 "G" series - Is this normal operation?
   / 2016 "G" series - Is this normal operation? #1
turbo36
Michigan
JD X739 AWS (3), 2016 Toolcat, JD 2038R
Hi all, I have a 2016 "G" series Toolcat 5600 with 100 hours on it. When I press the accelerator pedal slowly the unit will "chatter" as it accelerates, the opposite is true when I lift off the pedal and the unit coasts to a stop. It will not do it when cold but after 2-3 miles of road/field use it will chatter. It is really annoying , especially when I am in "worksite" mode and trying to inch up to something.
thanks, Bob
   / 2016 "G" series - Is this normal operation? #2
No chattering here and I have ~500 hrs on a 2017 model.
   / 2016 "G" series - Is this normal operation? #3
No chattering here. Is the hydraulic fluid level good and original?
After it is warmed up, put it up on 4 jack stands. See if it chatters and where it is coming from
I took it to the dealer for a full service, they updated the software and recalibrated the brake and throttle pedal. They claim the chatter is normal operation. Funny thing is I don’t recall this when I bought the unit new.
   / 2016 "G" series - Is this normal operation? #6
thanks, Bob
I have a 2016 as well and I get some noise during higher load driving. Could be described as chatter. Sounds like it hydraulic to me. I should take a video and see if you have the same symptom. I was thinking it could be dirt/debris in the little mesh screens in the hydraulic circuit causing some cavitation. I think these toolcats have those screens, I know my past bobcat skid steers did.
Mine is fine at high speed it is when I am coasting to a stop or slowly accelerating that I feel the chatter. It feels like the brake disc is "pulsating" for a lack of a better description.
   / 2016 "G" series - Is this normal operation? #8
The dealer can re-calibrate the brake system too.
   / 2016 "G" series - Is this normal operation? #9
Does it do the same thing in high and low range?
   / 2016 "G" series - Is this normal operation? #10
That sounds like brakes not fully disengaging. What's your top speed on flat ground in 2nd speed? A few others have had problems with brakes see these threads:
If you have Toolcat questions, ask them here... ---> HEY wait a second this is your post! so sounds like you've already concluded your brakes are dragging. This is definitely your chatter issue. I'd bet those brake discs are warped from overheating.
Unused IRTPL 10,000lb Two Post Car Lift (A55272)
Unused IRTPL...
3PT TOW BAR (A58375)
PALLET OF CENTRAL MACHINERY METAL CUTTING BANDSAW (A58376)
PALLET OF CENTRAL...
1987 International 1954 Elliott ECE 3-65H Telescopic Boom Lift Truck (A56858)
1987 International...
2008 Jeep Wrangler 4X4 SUV (A56859)
2008 Jeep Wrangler...
UNUSED X-STAR 20' LOADING RAMP (A58375)
UNUSED X-STAR 20'...
