2016 Branson 4520R Tach and Fuel Gauge Not Working - Not the Fuse
   / 2016 Branson 4520R Tach and Fuel Gauge Not Working - Not the Fuse #11
Dash/gage clusters?
Yes. I guess I should clarify different tractors not the same machine. Most older than the current back when the had the I on the end of some models. 3 of the 6 cleaned chicken houses the others were just peoples yard tractors.
   / 2016 Branson 4520R Tach and Fuel Gauge Not Working - Not the Fuse #12
Never had to do it myself, but I know there are places here in Portugal that would do it. They do it even on much more complex clusters from some of the vehicles we have here, like German vehicles and what not.
In the Branson case, sometimes even unplugging the cluster and plug back in will take care of some of these weird issues.
Yeah, that was tried we even turned it off and back on again! :)
   / 2016 Branson 4520R Tach and Fuel Gauge Not Working - Not the Fuse #13
Did you slap the side of it a couple times? That works... almost never
almost
almost
I did, actually. As you say, it basically never works.
   / 2016 Branson 4520R Tach and Fuel Gauge Not Working - Not the Fuse #15
almost
That worked on a 1994 Mitsubishi Pajero I had, exactly because it had broken solder joints on the tachometer. 🤣
   / 2016 Branson 4520R Tach and Fuel Gauge Not Working - Not the Fuse #16
Even though I answered your post earlier I forgot that my fuel gage stopped working early on and my fuel gage sender unit was also replaced under warranty.
Thanks.
1998 MACK CH613 DAYCAB WINCH TRUCK (A55745)
1998 MACK CH613...
2003 Big Tex 10PI...
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A55745)
2017 TROXEL 130...
Bobcat T590 (A53317)
2000 Ford F-550 Altec AT35-G 35ft Bucket Truck (A53422)
2000 Ford F-550...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A52705)
2021 HAMM HD+9I VO...
