2015 Mpower 85 won't start
   / 2015 Mpower 85 won't start #1
Hayboy83
Manvel, Tx
Mahindra 2565, Long 445, Massey Ferguson 1745 baler, John Deere 347 baler, New Holland 256 rake, Farmhand 8 bale grabbulator, Kawasaki 4010 Mule
I replaced the battery and the two 60a fuses and nothing. Won't turn, dash lights won't come on, nothing. Any ideas would be great.
   / 2015 Mpower 85 won't start #2
I'd check the ignition switch, and re-check your battery cables. Since you just changed the battery, I'd check to see if it's charged up (I'm sure you did, but just in case) May have a bad ground, or corrosion in a spot you didn't check. I recently found some corrosion in places I hadn't planned on in secondary connections. (not on top of the battery, but where other accessories "tie in" to the elec system.
Good luck and keep us posted !
   / 2015 Mpower 85 won't start #3
Cables off battery and to the starter.
   / 2015 Mpower 85 won't start #4
Why did you replace the fuses? Were they blown?
check the ground cable and it doesn't look corroded. It was hard to tell whether the fuses where blown, the copper on the old ones looked really dark so I was hoping it was a cheap fix. i think the CB radio was left on. I had to work on other stuff so I'll try looking at starter in the morning. thanks yall
   / 2015 Mpower 85 won't start #6
Multiple Mahindra folks have complained of mystery non start type issues and found the battery cables were corroded internally. May said they looked fine. Not trying to second guess you- just relaying what I’ve seen hanging out in the Mahindra forum.
   / 2015 Mpower 85 won't start #7
Sometimes a cheap probe, with the light bulb in the clear plastic handle can diagnose stuff like this better than a high impedance digital meter. Since the bulb draws a bit of power and you can gauge by the brightness of the bulb, the resistance of the circuit.
no power to switch, power to starter but that's it.
ground connection is really good, I think it's some type of relay. I got 33 acres that needs to be baled which I can do everything with my 2565 but now that one has a check engine light. I had to come back home so I'll try to load up the Mahindra Mpower 85 to bring it to the dealer next week. not a very productive three days at the ranch.
Land Honor 84" 3 pt Disk (A50514)
Land Honor 84" 3...
2019 VOLVO VNL760 TANDEM AXLE SLEEPER (A51219)
2019 VOLVO VNL760...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A52128)
2022 Quick Attach...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
2013 Chevrolet Traverse LS SUV (A50324)
2013 Chevrolet...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
