2015 Joystick leafing fluid
/ 2015 Joystick leafing fluid #1
Charlie175
Virginia
Mahindra 2015 gear
Enjoyed my tractor so far for about 40 some odd hours, works real good for my needs.
I noticed yesterday that I have some fluid leaking around on of the remote hookups on the joystick cradle. I assume I just need to tighten it up some or do I need to reseal it?
Also one of the lines leading in to the pump housing is leaking, this one would be harder to tighten since it is a 90 degree elbow, seems to have a lot of thread tape on it also.
/ 2015 Joystick leafing fluid #2
I would recommend attempting to see if they can be tightened any more and then clean them up so you can tell if it continues to leak or not.
Or should I just take it to my dealer for them to handle it under the warranty?
/ 2015 Joystick leafing fluid #6
I would just try to tighten it up first, no need to haul it to the dealer if it only needs a few turns of a wrench. If it continues to leak then I might take it to the dealer.
KAWASAKI 95ZIII Radiator (A68134)
KAWASAKI 95ZIII...
2018 MACK CXU (PINNACLE) (A67714)
2018 MACK CXU...
2025 20in. Rotary Brush Cutter Mini Excavator Attachment (A66734)
2025 20in. Rotary...
DEERE 410J Engine (A68134)
DEERE 410J Engine...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A64556)
2021 Mercedes-Benz...
2018 Deere 650K LGP (A64127)
2018 Deere 650K...
