2015 Implements
/ 2015 Implements #1
xcsm
Need some guidance on whether to purchase 4' or 5' implements for my 2015HST 4wd. Looking at buying a boxblade,bushhog and tiller. Appreciate any suggestions.
/ 2015 Implements #2
I am by far no expert but I would thing for your tractor 4' would be the maximum width.
/ 2015 Implements #3
I would go for the 5' on the box blade and tiller and even the rotary cutter unless you are going to be doing some heavy cutting. The tractor is wider than 4'.
/ 2015 Implements #4
I have a 60" finish mower that I typically mow with in 1st Hi, sometimes 2nd Hi (I have gear drive) depending on the terrain and grass.
I also have a 4' brush cutter that will bog the tractor down in high tough weeds, but it could handle a 5' if you reduce the speed. The front end gets light if I take my loader off, so watch for that.
I use a 60" box blade and it has worked out real well and last I have a 72" rake.
Hope that helps, your HST should have slightly less PTO power but the HST mow than makes up for that in versatility.
/ 2015 Implements #5
I second LAWALLSTRACTOR, and CHARLIE175.
My 2015 handles a 5' box blade pretty well. With the scarifiers all the way down, in heavy soil with rocks, It will stop the tractor though. Not a power issue, but a weight/traction issue. That's with R-4 tires. Ags would be better for that kind of work.
As far as a finish mower... 5 foot, no problem at all.
As far as the brush hog... I've used a 4 and 5 foot hog. Although the tractor has the power to run the 5 footer well, the weight of the hog can be an issue. If you use a 5 foot hog, leave the loader on, and pick up a scoop of dirt to help keep your steer tires on the ground
2018 INTERNATIONAL LT DAY CAB TRUCK TRACTOR (A69167)
2018 INTERNATIONAL...
1990 FRUEHAUF 53' DRY VAN TRAILER (A64280)
1990 FRUEHAUF 53'...
1992 Polar 307 SS T/A Insulated Chemical Tanker Trailer (A68183)
1992 Polar 307 SS...
2012 CHANDLER TRI AXLE SPD-18 WATER HEATING TRAILER (A67714)
2012 CHANDLER TRI...
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
2024 Texoma 16ft. T/A Equipment Trailer (A68183)
2024 Texoma 16ft...
