2015 HST with post hole digger
/ 2015 HST with post hole digger #1
LAWALLSTRACTOR
Veteran Member
Alexander, NY
Mahindra -------------
Has anyone used a 3ph post hole digger on a Mahindra 2015. I haven't had any of my customers give me any feed back on the use of a post hole digger on a 2015, as yet. My question is does it handle a standard cat I 3ph digger or is the lift height a problem. Are the diggers that are made for the subcompacts what I should be selling for this tractor or can I use the ones the standard cat I units. Your help would be greatly appreciated.
/ 2015 HST with post hole digger #2
I use a standard TSC (Speeco) on my 7205/2015. No problems at all. However if you are going to use an auger extension you do need to drill down a bit and then insert the extension. I think that might be common with a lot of smaller tractors though?
/ 2015 HST with post hole digger #3
I'm glad you started this thread.
I've been looking to find a digger for my 2015...hope you get a lot of good input.
Patiofarmer
Thank You, that is what I thought but I just wanted to make sure before I made the sale.
