Tires 2015 HST Filled Tires?
   / 2015 HST Filled Tires? #11
That was my whole point with the filled tires. No weight is added to the tractor components, (axles, either front or rear.) Any weight you add to a 3 point is carried by the axles, and lift hydraulics, and will take some weight off the front end, and in some cases that's not ALWAYS the best thing on a 4x4 tractor.
   / 2015 HST Filled Tires? #12
Dougster said:
Wouldn't the center of gravity actually be the same for equal weight added: wheel weights (or weight box at axle centerline height) vs. filled tires assuming uniformly distributed foam and not half-filled liquid?
Dougster
The correct procedure is to add weight on each end depending on how far the added weight is from the CG. But to figure that out you need to be up on your weight and balance formulas. :cool: The lower (in height) the weight is attached, the less top heavy the tractor is and thus has more stability for traction. Half or more (depending on how full) of a filled tire's weight is below the axle keeping the tractor bottom heavy where it counts for traction. Front bumper weights or 3PH weights are at or above the axle height. If they are lower you have overhang problems. Wheel weights would then be the next best thing to filled tires. Best thing to do is go with what your manual says. ;)
hugs, Brandi
   / 2015 HST Filled Tires? #13
bindian said:
The correct procedure is to add weight on each end depending on how far the added weight is from the CG. But to figure that out you need to be up on your weight and balance formulas. :cool: The lower (in height) the weight is attached, the less top heavy the tractor is and thus has more stability for traction. Half or more (depending on how full) of a filled tire's weight is below the axle keeping the tractor bottom heavy where it counts for traction. Front bumper weights or 3PH weights are at or above the axle height. If they are lower you have overhang problems. Wheel weights would then be the next best thing to filled tires. Best thing to do is go with what your manual says. ;) hugs, Brandi
I see you are thinking CG in two (or three) planes while I am thinking in one. I was thinking vertical plane, rear tires only and filled with foam which I thought distributed itself evenly... and therefore had the same net effect on CG as rear wheel weights of the same total weight.
The reason that I am focusing on this is twofold: 1) I am passing up too much work that involves traversing some serious slopes (with and without the BH in place), and 2) I am concerned that with non-filled, non-weighted industrial tires that I will have trouble in certain cases grading with a 7-ft box blade and maybe should stick with a heavy-duty (think: heavier weight) 6-ft box blade. Like you, I am up against my trailer's load limit and truck towing capability with the BH in place... so anything that can be added/changed at a jobsite (if it turns out to be necessary) is a big plus for me.
Dougster
   / 2015 HST Filled Tires? #14
art said:
Sorry I missed you guys. The steel weights on wheels is just as good as the liquid and you can get by with less because it doesn't hinder the tire flex which is what actually hurts traction.
To say the liquid is better because it is lower I question the differerence, both steel and liquid still use the same shaft or axle to attach to the tractor. To use a three point hitch weight does remove load from the front axle using the rear axle as a pivot.
From my experience, it doesn't seem like you need near as much weigh if you use cast compared to fluid. Something like 400 lbs. of cast vs. 6-700 lbs. of fluid ballast. It isn't scientific, just seat of the pants.
   / 2015 HST Filled Tires? #15
This has been my experience with my 7520, tractor by itself okay, added 4 sets of wheel weights, okay just a little better,:) but not enough. Added fluid to all 4 tires per owners manual, oh my goodness, I could hardly believe the difference.:D Not only does it seem much more stable, but I feel like the tractor actually rides smoother.:cool:
I guess that my tractor weighs in around 12,000 lbs with the FEL, I still need rear weight on the 3ph when picking up maximum loads and even with all that weight, I still can stop the tractor with all of my grading implements and they are 81"- 96" wide.
Just some of my experiences, yours may vary.;)
   / 2015 HST Filled Tires? #16
I'd say your air presssure was off to begin with, I've never seen what you described for peformance. To have a loaded front tire is way over loaded for all but total heavy earth movement day in and out.
   / 2015 HST Filled Tires? #17
Each to his own, the performance of my tractor is quite good I believe. My tires have 20lbs in the rear & 46lbs in the front. The maximum rated inflation, the tires bulge with the loads that are commonly carried. I am not going to change tire pressure on a regular basis to get optimum traction. I very seldom do one type of work for more than 1 day. That is why I have a utility tractor, and I have chosen what seems to work best for me in my environment.:)
   / 2015 HST Filled Tires? #18
Dougster[/QUOTE]
Dougster,
You can always carry a water hose and fill the tires at the job site. :eek: :D ;)
hugs, Brandi
   / 2015 HST Filled Tires? #19
From the photos I have seen of MtnViewRanch............you are describing Brian's operation. ;) His 7520 and my 6520's front tires are bigger than a lot of little CUT's REAR tires. :cool: Just curious, what kind of mistake did you make with filled tires?:confused:
hugs, Brandi
   / 2015 HST Filled Tires? #20
That's just down right embarassin' that a girl has tires bigger than mine!
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A52128)
2003 International...
(2) SODA FLO CONTAINERS (A51244)
(2) SODA FLO...
John Deere 922 Platform (A50514)
John Deere 922...
UNUSED FUTURE SKID STEER PALLET FORKS (A51244)
UNUSED FUTURE SKID...
New Holland 489 Haybine (A50774)
New Holland 489...
2018 Nissan Murano SUV (A50324)
2018 Nissan Murano...
