2015 F150 Tow Test vs. Dodge and Chevy
   / 2015 F150 Tow Test vs. Dodge and Chevy #111
The aftermarket will have steel repair panels I'm sure. They make steel hoods for vehicles that came with aluminum.
   / 2015 F150 Tow Test vs. Dodge and Chevy #112
I hope they never try to make aluminum alloy wheels, they will never sell.
What Aluminum Wheels, now that's just plain silly....:eek::confused2:
   / 2015 F150 Tow Test vs. Dodge and Chevy #113
And when they make an aluminum engine block I'm walkin....
Chris
   / 2015 F150 Tow Test vs. Dodge and Chevy #114
Chris
And run for the hills when they make a combination of aluminum block with iron sleeves. It will never work. How could two dissimilar metals coexist? From where I have my head buried in the sand, I can not see this working.
   / 2015 F150 Tow Test vs. Dodge and Chevy #115
What type of aluminum we talking about?
Wait for the carbon reinforced hemp panels!
   / 2015 F150 Tow Test vs. Dodge and Chevy #116
Yes, but aluminum aircraft were considered way more sturdy than their predecessors the sticks, glue, canvas and spit models.:) It is ALL relative.[/
On some new planes aluminum has been replaced by none metallic moulded materials.
The plywood Mosquito seemed to do well for itself!
   / 2015 F150 Tow Test vs. Dodge and Chevy #117
Only available in California and Colorado.
Chris
   / 2015 F150 Tow Test vs. Dodge and Chevy #118
I think some interior panels may already be in use ???
   / 2015 F150 Tow Test vs. Dodge and Chevy #119
Ford will make it up when people start to repair their vehicles (body work). For the most part the only companies that will supply repair panels for the F150 will be Ford. People can say what ever they want about the cost of a new vehicle. The real price check will be in the difference between the cost of a steel fender and an aluminum fender. Right now a steel hood on a Chevy 1500 is almost half the cost of an aluminum hood on a F150. Not quite apples to apples comparison but it's close. Aftermarket companies will have to do the same engineering that Ford has done to ensure they can make a product that will fit correctly.
Very true. Best way to compare the costs is to look at the exact same body panel made with steel and compare the costs to the one made of aluminum. No way to spin it at that point.
   / 2015 F150 Tow Test vs. Dodge and Chevy #120
Some of the comments on this page are confusing. I don't think anyone has suggested aluminum won't work. Just that it will likely cost more which is absolutely true. As crazyal pointed out if you compare the same panels made from steel versus aluminum it is pretty obvious.
2013 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2013 Ford F-550...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR6BJ325793 (A51572)
2011 International...
1986 ASPT 30ft S/A Pole Trailer (A49346)
1986 ASPT 30ft S/A...
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A51039)
2021 New Holland...
(INOP) CATERPILLAR 416B BACKHOE (A50459)
(INOP) CATERPILLAR...
