2014 z-force sz54 kw transmission question
   / 2014 z-force sz54 kw transmission question #1
Sigogglin
Goshen, VA
New Holland TC45DA
My drive belt slipped off and while I was under there getting back on I noticed build up of dirt on the LH transmission. It appears that a seal is failing. Anyone know if you can replace the seal? I'm not hopeful, but figure it is worth a shot before I spend $900 on the part.
This appears to be the replacement part:
CubCadet - 918-5127A
I looked at Hydro-gear and they seem to be the closest in style, but their controls are on the outside (by the axle) and the cub cadet is on the inside.
thanks
david
   / 2014 z-force sz54 kw transmission question #2
Thanks for that help. I found that I actually have the 2015 17AIDGHC010. That transmission matches the picture on partstree. It is the seal by the brake rotor that appears to be leaking.
I also learned that there is a filter for each side. It is hidden behind a plastic shield. Now to figure out at how many hours are they to be replaced. I have ~536 hours on it.
I found the transmission service manual in case anyone else is interested:
http://www.hydro-gear.com/768118d525_sites/hydro-gear.com/files/BLN-52441_P19.pdf
and yes, I'm do a filter change on the transmissions.
thanks
david
   / 2014 z-force sz54 kw transmission question #4
The service interval should be in the manual. Commonly they spec an early change at 50-100 hours and then every 400. Easy to do. Remove the ~3 screws on each filter cover and clean the case well before changing. Use the HG filters and 20w50. They have regular kits which work out nice too. Somehow the fluid goes back in...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
Club Car Carryall 500 (A50121)
Club Car Carryall...
Swict 66" Skidloader Bucket (A50774)
Swict 66"...
2018 John Deere 470G Hydraulic Excavator (A50322)
2018 John Deere...
2019 JLG 2682 26FT Scissor Lift (A50322)
2019 JLG 2682 26FT...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
