2014 Troy Bilt Pony 13WM77KS011 SN 2E234B80121
   / 2014 Troy Bilt Pony 13WM77KS011 SN 2E234B80121 #1
texascedar
South Central Texas
JD 850, LS J2023H
My neighbor gave me this mower yesterday along with a piece of a part that I have identified as part of the variable speed pulley.
Check photo. What could cause this to happen? I have the part ordered but don't want to end up with another broken part.
Also any tips on how to change out the part would be appreciated.
Thanks
   / 2014 Troy Bilt Pony 13WM77KS011 SN 2E234B80121 #2
That's strange. If the belts had a flat spot maybe? You will want to use only OEM belts BTW. I guess just be sure it is mounted securely and the bearings new (941-0600).
I replaced the pulley and the mower does forward and reverse just fine now even with the old belt.
   / 2014 Troy Bilt Pony 13WM77KS011 SN 2E234B80121 #4
Could have been a defective part or the nut came loose maybe. 2014 unit is really not that old unless some one beat the daylights out of it.
I have a Troy Built Pony since around 1996 overall its been flawless and I worked I hard for many tears. Broke a few tines and the welds on the handle bare brace even wore the valves down in the little briggs motor that I eventually relapped and set clearance over (it was having a loss of power al good now tho)
Never had belt an or pully problems that I can ever remember.. I'm thinking I did replace the belt though once
I should clarify. This unit is a Pony riding lawn mower.
2003 Club Car DS Electric Cart (A51694)
2003 Club Car DS...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52706)
KNOW BEFORE YOU...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
Pull-Behind 66in Smooth Drum Ballast Roller (A51691)
Pull-Behind 66in...
2013 Ford F-550 Passenger Bus (A51692)
2013 Ford F-550...
Brushfox XHD-78 (A53421)
Brushfox XHD-78...
