2014 Mahendra 6110 over heats-Olease Help
   / 2014 Mahendra 6110 over heats-Olease Help #1
sammie
ms
Mahindra tractor
Please help, I have a 2014 Mahendra 6110 that over heats after 2 hours running my bush hog. the tractor is 4 years old with 800 hours on it, and this is the first time this tractor has started doing this over heating problem. My tractor is well maintained and I use it once a week to cut about 10 acres of grass, which takes me about 4 hours to cut. I run the AC, but this has never been a problem in the past 4 years. I have had to raise my bush hog about 1 inch up off the ground so the skids on the bush hog does not drag and put extra stain on my tractor. This is also something new that I have had to do to get it to run the 2 hours before it over heats and I am done for the day. The radiator is full and there is no leaks any where and the radiator and screen both have been cleaned by compressed air with a long wand and water with a garden hose. It is still under warranty. I Thank you for any help. Sincerely Sammie
   / 2014 Mahendra 6110 over heats-Olease Help #2
I would guess the radiator needs cleaning;blow out with compressed air(engine off),remove any screens from the front of the rad and clean.Some use a water hose,I found that a long wand and compressed air works well.
Blow from the engine to the front.
   / 2014 Mahendra 6110 over heats-Olease Help #3
Agree- it’s a maintenance and cleaning issue. It’s flat plugged.....
   / 2014 Mahendra 6110 over heats-Olease Help #4
Also blow out your air filter(s).
2013 Dodge Journey SXT SUV (A50324)
2013 Dodge Journey...
Kivel Pallet Forks (A50121)
Kivel Pallet Forks...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
2014 Hitchai ZX470LC-5B Excavator (RIDE AND DRIVE) (A50774)
2014 Hitchai...
