2014 Kubota l3200 hst starting problem
   / 2014 Kubota l3200 hst starting problem #1
Mike from MI
Bellevue,Mi
Kubota l3200 hst 2014
Hi All
Need help with 2014 Kubota l3200 HST not starting. Sometimes when I go out to start tractor I'll turn key back to light glow plugs turn key to start and I get just one click sound, then nothing will not start, no lights will come ie flashers, head lights.
Will not jump start with a truck or jump box but when I hook up to my large charger fires right up with in seconds. Then it will stay fine for a couple of weeks and problem will return.
I have seen other post suggesting moving levers and petals around, has no effect on mine.
Anyone have an idea what's going on.
My first post
Thanks Mike
   / 2014 Kubota l3200 hst starting problem #2
Next time it fails to start, I'd put a volt meter on the battery, then follow to the fuse box. And try to start at each. Is there a difference in the way the charger clamps to the battery then your cables?
   / 2014 Kubota l3200 hst starting problem #3
Almost sounds like a loose connection, either on the battery terminals or ground strap.
I will give it a try the next time. Clamps are the the same on jumpers and charger as soon as I put the charger on it fires right up.
Thanks Mike
Have checked ground has good contact at both ends.
Thanks Mike
Just wanted to update. I took ground cable off battery and frame, took wire brush to frame and cleaned post put cable in vice put a little pinch on the crimps then put back on. Haven't had a problem since it's been about a mouth now.
Hope I don't jinks it with this update ;)
Thanks everyone for your help.
2018 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A51242)
2018 CATERPILLAR...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
1991 Cleveland Equipment Trailer (A50514)
1991 Cleveland...
2015 FREIGHTLINER  CASCADIA (INOPERABLE) (A50854)
2015 FREIGHTLINER...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
2022 Adams CLC-1013 Conveyor - New (A51039)
2022 Adams...
