2014 John deere WAM electrical troubleshooting
   / 2014 John deere WAM electrical troubleshooting #1
Green35
Greenville,SC
John deere 1600 turbo
We have a 2014 WAM that blew the 15 amp main electrical fuse replaced it and ran for 2 to 3 more hours.We tried to crank it up the next day and nothing fuse is good battery was old and worn out so we switched with our other batwing still nothing.So then put cables on it sounds like its charging up "beeping gets louder the longer you wait to crank it". Battery is good ignition switch is good jumped out a diode and we get the fuel pump to come on but don't know where to go from there any help would be appreciated.
   / 2014 John deere WAM electrical troubleshooting #2
I'm curious... what is a WAM ?
:welcome: to TBN
Okay, figured it out.. a Wide Area Mower .
   / 2014 John deere WAM electrical troubleshooting #3
Check all grounds for corrosion and that there tight.Be sure all safety switches are good.
   / 2014 John deere WAM electrical troubleshooting #4
There are two diodes on your machine from what I see on the Deere web site.
Knowing what they are for, I don't understand your comment of "jumped out a diode.|"
Do you have or can you buy a cheap multi meter.
Once you have that I suggest you do the voltage drop tests outlined starting at page 8 of the DENSO starting trouble shooting guide.
http://densoautoparts.com/sites/default/files/tech-tips/DENSO Starter troubleshooting tips.pdf
Dave M7040
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
6" & 8" I BEAMS UP TO 16' LONG (A51247)
6" & 8" I BEAMS UP...
GEHL RB1470 TOTAL DENSITY CONTROL HAY BALER (A51247)
GEHL RB1470 TOTAL...
2008 JLG 450AJ SERIES II MANLIFT (A51246)
2008 JLG 450AJ...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
