2014 BX1870 Steering Frame Broke
   / 2014 BX1870 Steering Frame Broke #1
JimBinMI
Coldwater, Michigan
2014 Kubota BX25D-1, 2014 Kubota BX1870
I was mowing a couple days ago and noticed my steering wheel was really sloppy, moved up down left right. After some research I was hoping that the bushings were shot. Tore it apart today and find a broken mount, looks like it's a very large part totally. Attaching some pics, has anyone had this problem and how did you solve it? I have a MIG welder.
   / 2014 BX1870 Steering Frame Broke #4
It is a cast aluminum, repairable, but it sound like you might not have the equipment to do the repair.
   / 2014 BX1870 Steering Frame Broke #5
OMG, that is a nasty condition. The labor to get the guts of that tractor apart and get that broken casting out by itself to work on is formidable. That sort of job intimidates me. If I were you (and could do it) I would save a huge labor bill by disassembling the machine and removing the casting. Then go to Kubota and buy a new casting and reinstall it. I would not try to weld or repair it...but that is just one opinion. My guess is that is a VERY rare breakage (how the heck did it happen!?) I'd also by concerned about availability of such a part...
   / 2014 BX1870 Steering Frame Broke #6
My guess it happens when one uses the steering wheel to pull yourself up on the tractor. My wife does that on our BX22. I've replaced the steering wheel once because of that practice.
   / 2014 BX1870 Steering Frame Broke #7
Depending on S/N, Messick's have them in stock. $250-$265 for the pair.
   / 2014 BX1870 Steering Frame Broke #8
Being a life long welder if you decide to repair them take the parts to a real welding shop. Because welding aluminum is nothing like welding steel and cleanliness this is next to Godliness with aluminum. Plus the shop can weld on a stiffener or fish-plate so that it will be stronger than original because we know it was not strong enough for the job it had to do. It can be Tig welded or if they have a spool gun then aluminum Mig welded.
   / 2014 BX1870 Steering Frame Broke #9
The steering assembly is something I've worried about the whole time I have had my L3301. I keep a woody 4 ac on my property clean and it's rough as a cob. Old stump holes are the worse and you don't see them until one of the front wheels fall into one. There is a lot of old stumps that still have not rotted away and I'm always banging into those as well. The underbrush and briers grow so fast it's hard to see any of this stuff. I try to back into most of the really bad spots but that's hard on my old back. I worked for 3 years with smaller tractors, wore 2 of them completely out before I finally got it cleaned up. Some places were so thick with briers that I would have to pull up to those places turn it up to wide open in first gear and jump off and run around to the other side and jump back on and go in the back side time and time again until I got it to where I could get in there without getting skinned alive by those huge bamboo briers. I used an old Gravely L model for a while but that was a giant pain because one of the wheels was constantly falling into one hole or another even with dual wheels it was a real pain to get it out and going again.
Since the two parts were under $300 at my local Kubota dealer I ordered them last week and they were here yesterday. I picked them up yesterday and have been tearing into the BX1870 for hours. I don't mind doing this stuff but some of those nuts have been hard to reach. Thinking I might have to remove the radiator...which I just had out to clean it! Came in the house to get on the computer to see if I could find some manuals/hints how to proceed. At least I have the BX25D that I can mow with until the BX1870 is back together. I bought the BX25D new in 2014, bought the BX1870 used November of 2023.
2011 JACK 130BBL (A53843)
2011 JACK 130BBL...
2014 Nissan NV200 Cargo Van (A53422)
2014 Nissan NV200...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
2013 PETERBILT 389 (INOPERABLE) (A55745)
2013 PETERBILT 389...
18" PIN ON BUCKET (A52707)
18" PIN ON BUCKET...
