2013 kubota l3800 starter problems
   / 2013 kubota l3800 starter problems #1
MURPHYS
murray,ky
2013 kubota l3800
Starter stayed engauged, i disconnected battery, pulled starter off & then put back on, still engauged, what next?
   / 2013 kubota l3800 starter problems #2
You tested the starter in some manner before putting it back on, right? What did that show you?
   / 2013 kubota l3800 starter problems #3
Take the starter to a Auto Zone if one is close by and they can test it and determine if it is bad and in need of replacement. If the replacement route is pursued, you might consider contacting this company. KUBOTA 16241-64010 THRU 19269-63013 ALTERNATORS AND STARTERS BY OEM #. You will probably suffer a severe case of "Starter Shock" if you purchase at the Kubota Dealers.
   / 2013 kubota l3800 starter problems #4
Is it out of warranty?
Bendix is engauging without key in ignition
Bendix is engauging without key in igition
yes, only had 1 yr.
   / 2013 kubota l3800 starter problems #8
If its under warranty, contact your dealer.
Starter still trying to start the tractor without the key even in the ignition sounds like a wiring issue to me. The big heavy starter wire is normally hooked straight to the battery. And the smaller wire is the solenoid wire that momentarily gets 12v when trying to start. (thats a typical start curcuit and I dont know for sure if thats how the L-series are). I'd have to look at mine. But I'd be unhooking that small wire and see if it has 12v on it at all times. if it does, there is nothing wrong with the starter.
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A56858)
2013 International...
2019 CATERPILLAR 305.5E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2002 TOYOTA 7FDKU40 FORKLIFT (A57880)
2002 TOYOTA...
