2013, Kubota B-2920 Heater installation
   / 2013, Kubota B-2920 Heater installation #1
javahjoe
Kokomo, IN
Kubota, Power King
I have completed installation of my heater in my Kubota, B-2920, with an Original Tractor Cab, made right here in, INDIANA. Turned out to a good installation, as I installed it overhead. Now if I can find how to post pictures, I'll show it off. javahjoe, MIO, P K Junky, aka Don Kubota Heater 2.jpg
   / 2013, Kubota B-2920 Heater installation #2
I have completed installation of my heater in my Kubota, B-2920, with an Original Tractor Cab, made right here in, INDIANA. Turned out to a good installation, as I installed it overhead. Now if I can find how to post pictures, I'll show it off. javahjoe, MIO, P K Junky, aka DonView attachment 365500
What brand of heater, fan speeds, BTU rating? Looks good. lt190b
The complete heater unit is for an Astro Van aux heater. I have it on an on-off swtich, but intend to install a 3 speed switch. BTU's, about 12000
   / 2013, Kubota B-2920 Heater installation #4
javahjoe. Looked at your pictures on the other thread. This could work in a skid loader also. Where did you find out about this heater? Have you had a chance to use it in cold temps, how well does it work? lt190b
I bought the heater unit off ebay. Do an ebay search, Astro Van Aux Heater. I just look at ebay, and they have gone up in price. Now around $71, but that is for the complete unit. Fan, heater core and shroud. This is a nice unit at a reasonable price. My cab is a soft side cab, and is not weather tight. However, makes it nice and cozy inside, while moving snow. The hard part was configuring the plumbing, and buying the fittings. The inlet and outlet on the heater core are 3/4, and I ran 5/8 off the rad hose, because that was the size of the T. I ordered the heater hose kit, (no hose, just T's) from my Kubota dealer. If I had it to do over I wouldn't order from the dealer. I searched the net and found what I needed, after I bought the kit. As I said, I used pipe to get the coolant by the muffler. That worked out nicely for me. O'Reillys's Auto Parts had most of the fittings, and some were from Ryder, off the net. javahjoe, MIO P K Junky, aka Don
   / 2013, Kubota B-2920 Heater installation #6
javahjoe, whats the chance of getting some dimensions of that heater? LxWxD lt190b
Sure! 19 long x 10 wide x 7 tall. Do a web search for Astro Safari, Van GMC part 15853800. Anything else I can help you with? Always glad to be of help. javahjoe, MIO, P K Junky, aka Don
   / 2013, Kubota B-2920 Heater installation #8
javahjoe, thanks for all your info. I did a search on ebay but couldnt contact seller, I'm not registered there. Thanks again lt190b
   / 2013, Kubota B-2920 Heater installation #9
Javahoe
Could you post a pic or two showing where you tapped into the cooling system? Thanks.
I came off the top rad hose with a T. That is for the return. I removed the engine block drain plug, between the oil filter, and the starter. and hooked in the out going hose. Kubota Heater 4.jpgKubota Heater 5.jpgKubota Heater 6.jpg
2024 KMC 7406 (A53084)
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
2020 John Deere 260E 26 Ton Articulating Off-Road T/A Dump Truck (A50322)
2020 John Deere...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
