2013 Kioti CK35 HSTS Axle drain plug leak
   / 2013 Kioti CK35 HSTS Axle drain plug leak #1
WiKioti
Eau Claire, Wisconsin
CK35
:eek:On the left rear side of tractor as you are sitting on the seat, the drain plug is leaking. It is snug and tight. Last year I changed oil and everything has been fine till about a month ago I noticed fluid on floor of pole shed.
I wiped this area clean, and sure enough the drain plug a minute later is leaking. Local dealer, said to buy and install an new drain plug. Duh.
Anyone have this issue or is there a gasket plastic or otherwise to seal this up. Any ideas are great, even though I have to drain it again just to fix problem.
this baby runs just great, with about 150 hours on it now.
Wikioti
   / 2013 Kioti CK35 HSTS Axle drain plug leak #2
I have a 2005 CK30hst. My drain plugs have gaskets. I haven't had a problem with them leaking after 4 oil changes.
2025 New/Unused Wolverine Concrete Breaker (A51573)
2025 New/Unused...
Case 580B Backhoe   (A52384)
Case 580B Backhoe...
Pallet Forks for Tractor (A51573)
Pallet Forks for...
2003 Ford Excursion 4x4 (MPV), VIN # 1FMSU43PX3EC07978 (A51572)
2003 Ford...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A52576)
2015 VOLVO VNL...
2021 BOBCAT T450 SKID STEER (A51246)
2021 BOBCAT T450...
