2013 JD 4720 Hydraulic Pressure Relief
   / 2013 JD 4720 Hydraulic Pressure Relief #1
jghop10
JD 4720
Hello all,
I am looking to increase my hydraulic pressure on my 2013 JD 4720 because I checked the pressure and it was 2300 psi. The problem I have ran into is I cannot find the relief valve to do the adjustment I tried to use the picture provided in the technical manual (photo attached) however there was nothing there and the configuration is different. If anyone has any information on how to adjust this it would be greatly appreciated. Thank you.
   / 2013 JD 4720 Hydraulic Pressure Relief #2
Parts shows a relief valve on a two spool valve.
Thank you so much Zebrafive, I know exactly where that is located to. I wonder if tightening or loosening the nut on the exterior will adjust the pressure or if it needs shims. Thank you.
   / 2013 JD 4720 Hydraulic Pressure Relief #4
Just guessing............no shims, nut locks adjustment. Loosen nut, turn center shaft, tighten nut. Again this is a guess.
2004 Range Rover HSE SUV (A51694)
2004 Range Rover...
LMC LOT NUMBER 141 (A53084)
LMC LOT NUMBER 141...
2020 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2020 KOMATSU...
Skid Steer Sweeper Attachment (A51573)
Skid Steer Sweeper...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
