Mowing 2013 5083e (69 pto) - 15' Rotary Cutter
   / 2013 5083e (69 pto) - 15' Rotary Cutter #1
skoalman12
TX,TX
2013 5083e
Just bought a new 5083e. Does anyone currently use this tractor (or similar powered) with a 15' shredder? If so, does is handle it ok?
I bought an 8' shredder from my dad to use for now later I plan to upgrade to a 15' when I can afford it. I have 250 acres to mow annually.
My dad has a Kubota 7040 (60 pto) that he mows with 15' shredder with, it does fine, I've mowed with it. I had to clutch down some mowing thick nuts edge. But I also attributed it to a (not so robust) transmission 8x8.
Note: my dad mows 700-1000 acres with his annually.
Anyway... Thoughts??
   / 2013 5083e (69 pto) - 15' Rotary Cutter #2
You can handle a light 15' mower no problem. You have plenty of power to run it, but I find the 3pt hitch on the E's rather dissapointing especially the lift capacity.
What does 3pt have to do with it? These are pull-type shredders.
   / 2013 5083e (69 pto) - 15' Rotary Cutter #4
On relatively flat land in light to medium grass/brush it should do ok. We use a 15' woods batwing on a M9540 Kubota (82 PTO hp) and it's about about as small as I'd want to go with the hills and tough conditions we have around here. Ideally you want 100+ pto hp to really get full use out of a batwing, but you can get by with less if you take your time.
   / 2013 5083e (69 pto) - 15' Rotary Cutter #5
Sorry, didn't know you were talking about a drawbar pull mower. I do know someone with a 2013 5093 with a 15' rotary mower (3pt lift) and it handles it fine but it is not a heavy duty model.
It's my fault I wasn't clear. Plus didn't know 15' 3pt mowers existed.
Thanks for the info everyone.
20 BLADE DISC HARROW, 3PT (A52708)
20 BLADE DISC...
New Holland 1412 Discbine Pull Type Mower Conditioner / Windrower (A56435)
New Holland 1412...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
SNAPPER 28" MOWER (A52708)
SNAPPER 28" MOWER...
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
