2011 branson 4720h
/ 2011 branson 4720h #1
ARNAUDVILLE
ARNAUDVILLE LA.
BRANSON 4720 H
my tractor creeps forward and reverse so I have to play back and forth to get it in neutral they say loosen adjusting screw and move one not forward or I backward , so if I set it back one one not backward will that affect the for forward wont the reverse, also I just changed my transmission oil and when I turn it on it flashes what looks like a front and rear transmission , could it be I need more oil I changed transmission and hst filters ,
/ 2011 branson 4720h #2
On my 3725 there's an oil level sight glass on the back of the transmission.
The shop manual covers how to adjust the HST pedals.
/ 2011 branson 4720h #3
my 4720h creeps either forward or reverse too. It's worse when it's hot. I've adjusted the cam under the F/R pedals, it helped but didn't fix it. The only thing I do now if I can't tap the F/R pedal to make it stop is to crank on the parking brake or shift the lever to Neutral.
It's a PITA when I'm pulling trees or something that requires me to stop and exit the vehicle often.
/ 2011 branson 4720h #4
Did you put in the correct fluid ? I know that may be a dumb question but I did buy one once that had issues and that was the problem.
EZ Go TXT Golf Cart (A61166)
EZ Go TXT Golf...
(14) 24X48" FLOURESCENT CEILING LIGHTS (A64281)
(14) 24X48"...
2016 KUBOTA RTV-X900 UTV (A64280)
2016 KUBOTA...
2017 Chevrolet Express 3500 14FT Box Truck (A61573)
2017 Chevrolet...
2010 Acura MDX AWD SUV (A61574)
2010 Acura MDX AWD...
2014 BMW X1 S28i SUV (A61574)
2014 BMW X1 S28i...
