2011 branson 4720h
/ 2011 branson 4720h #1
ARNAUDVILLE
ARNAUDVILLE LA.
BRANSON 4720 H
my tractor creeps forward and reverse so I have to play back and forth to get it in neutral they say loosen adjusting screw and move one not forward or I backward , so if I set it back one one not backward will that affect the for forward wont the reverse, also I just changed my transmission oil and when I turn it on it flashes what looks like a front and rear transmission , could it be I need more oil I changed transmission and hst filters ,
/ 2011 branson 4720h #2
On my 3725 there's an oil level sight glass on the back of the transmission.
The shop manual covers how to adjust the HST pedals.
/ 2011 branson 4720h #3
my 4720h creeps either forward or reverse too. It's worse when it's hot. I've adjusted the cam under the F/R pedals, it helped but didn't fix it. The only thing I do now if I can't tap the F/R pedal to make it stop is to crank on the parking brake or shift the lever to Neutral.
It's a PITA when I'm pulling trees or something that requires me to stop and exit the vehicle often.
/ 2011 branson 4720h #4
Did you put in the correct fluid ? I know that may be a dumb question but I did buy one once that had issues and that was the problem.
