2010 Scag Tiger Cub KAWA FH580V - Bogging down
   / 2010 Scag Tiger Cub KAWA FH580V - Bogging down #1
MexTex
Magnolia, TX
Scag Tiger Cat
Hello everyone and Happy Easter!
I have been having some issue with my Scag and I was hoping someone could help me figure out what is going on. The problems started occurring after I performed some routine maintenance. Here is what did: added fuel to the tank mixed with a little Seafoam. Inclined the mower, removed the blades, sharpened and reinstalled. I didn't have much time to get to the blade sharpening so it remained inclined for about 3 weeks. Once I finally mounted the blades and dropped the mower, I started the mower up and attempted to mow the yard. It started up fine, but as soon as I put it in a higher RPM it seemed to bog down. I started the blades and it bogged down even more. I shut the mower down and noticed that I failed to plug in the wire to the spark plug. I plugged the wire back in, started it up and the mower ran fine. The following week I took the mower back out to mow the yard again and again it bogged down at high RPM's and worse when I engaged the blades. I shut the mower down and removed the spark plug and went ahead and replaced it - no change. I checked out the battery and it is reading 13 volts. I connected the multimeter to the battery and started up the mower, increased the RPM's and even started the blades and the voltage stays above 13 volts throughout. Any ideas?
BTW: I can turn on the mower, kick the RPM's all the way up, turn on the blades, and then turn the mower hard right or left and the engine will die. It also bogs down without the blades being engaged and the mower at full speed, so I eliminated something being wrong with the deck, but it doesn't die.
Thank you in advance.
Mower Information:
2010 Scag Tiger Cub STC48V-19KAI
Kawasaki FH580V KAI 19.0HP
   / 2010 Scag Tiger Cub KAWA FH580V - Bogging down #2
What exactly is bogging down? Decreased RPMs? Rough running? Slows down going up a steep hill? Why did you use the Seafoam? The spark plug wire was off completely? Are there 2 or more plugs on that mower? You may have damaged a coil to the plug in question...
   / 2010 Scag Tiger Cub KAWA FH580V - Bogging down #3
With the engine running, use a pair of insulated pliers and remove you plug wires one at a time. See which cylinder is not carrying any load and check it for spark.
Its possible the coil you left unplugged is damaged.
2006 Ford Fusion SE Sedan (A51694)
2006 Ford Fusion...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
(4) Sumitomo 11.00 R22 Tires (A51573)
(4) Sumitomo 11.00...
2007 Hino 268 Cab and Chassis Truck, VIN # 5PVNJ8JV672S50269 (A51572)
2007 Hino 268 Cab...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A53472)
2012 RAM 5500...
