2010 power steering help
/ 2010 power steering help #1
rusty022
Michigan
John Deere 3020 New holland TC25D
I just purchased the tractor. It had a hydraulic leak. I cleanit up a can see the leak is coming from the power steering unit below the steering wheel. The right side metal line. It looks like it is a newer line too. I haven't got in there to take it apart yet, but does anyone know if it is a flare tube like a brake line or does it have an oring on it. I checked to make sure it was tight. Thought maybe if it has an oring, that it might be bad. If not I must have alot bigger problem with it.
/ 2010 power steering help #2
Look the parts up in jdparts.com and/or stop by the Deere dealer to find out. Should be able to see it clearly enough.
After about 4 hours of removing things to get at the line fairy easy. I found out the new line is cracked by the fitting.
