2010 power steering help
/ 2010 power steering help #1
rusty022
Michigan
John Deere 3020 New holland TC25D
I just purchased the tractor. It had a hydraulic leak. I cleanit up a can see the leak is coming from the power steering unit below the steering wheel. The right side metal line. It looks like it is a newer line too. I haven't got in there to take it apart yet, but does anyone know if it is a flare tube like a brake line or does it have an oring on it. I checked to make sure it was tight. Thought maybe if it has an oring, that it might be bad. If not I must have alot bigger problem with it.
/ 2010 power steering help #2
Look the parts up in jdparts.com and/or stop by the Deere dealer to find out. Should be able to see it clearly enough.
After about 4 hours of removing things to get at the line fairy easy. I found out the new line is cracked by the fitting.
2023 Isuzu NRR Crew Cab 20ft Dovetail Flatbed Truck (A61573)
2023 Isuzu NRR...
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
2018 Ford Escape SUV (A61574)
2018 Ford Escape...
AGI Westfield WRX 8-61 (A64126)
AGI Westfield WRX...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
(INOP) 2012 INTERNATIONAL DURASTAR 4300 SBA TRUCK (A59823)
(INOP) 2012...
