2010 F250 tow question
   / 2010 F250 tow question #1
yellowdogsvc
Platinum Member
S. Central TX Hill Country
I just picked up a 2010, F250 4x4 CC king ranch (I think it has bigger tires than my lariat F350) with 6.4 and short bed.
I noticed it only has a 2" Class IV receiver rated at 12500. I need it to occasionally pull a 12,600 lb chipper and 13k rated trailer.
My question is I've seen some Class V hitches that say they will fit the F250. My concern is will the F250 handle the Class V and that weight trailer? I have an '08 F350 with class V 2.5" and didn't even notice that the 2010 F250 had only a 2" class IV. If this truck can handle a Class V hitch, will the 20" spare tire and ranch hand style rear bumper be a problem?
   / 2010 F250 tow question #2
It can pull the weight but its all going to come down to tongue weight and the limits of the 20" tires.
Chris
   / 2010 F250 tow question #3
I have a srw 2008 f350 crew cab and upgraded the hitch to a 2.5", can't remember the brand off hand. I pull a 14k dump trailer and it handles fine. I think the aftermarket 2.5" hitch is rated for 1800 lbs of tongue weight. I have 18" tires and the v10.
Ford dealer told me today that they could install the the Class V for $599 which I thought was reasonable and then it's done through the dealer. Evidently, the truck can handle it. My father in law's F250 SRW, 2011, is rated at 14 or 15k bumper pull.
   / 2010 F250 tow question #5
Its a easy swap. I can get the hitch for about $300 and swap it out in 15 minutes.
Make sure you buy a 2.5" receiver and ball with load ratings to match.
Chris
   / 2010 F250 tow question #6
put an adapter in the 2.5 hitch to go down to 2 my 2 ball mount is rated 16k that a B&W hitch most 2.5 are rated 14k at TSC any way
   / 2010 F250 tow question #7
Skip TSC. I get ball mounts at my camper dealer rated at 25,000#, same for the balls.
Chris
   / 2010 F250 tow question #8
Here is a 15K hitch for $215 that fits your truck. They should be able to do a hitch in less than a hour.
I have installed Curt hitches before. I think they are nice than a Reese or Valley.
2001 CATERPILLAR 140H VHP MOTORGRADER (A51406)
2001 CATERPILLAR...
1999 John Deere 4300 (A50123)
1999 John Deere...
2006 Ford Fusion SE Sedan (A51694)
2006 Ford Fusion...
John Deere 853 20ft Corn Head (A53473)
John Deere 853...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
2025 SDLANCH SDLE20 UNUSED Mini Excavator (A53117)
2025 SDLANCH...
