2010 DK45SE stalls when idled
   / 2010 DK45SE stalls when idled #1
tractorsam
New Germany, NS
Kioti DK45SE HST Cab
I have a 2010 DK45SE HST cab tractor with just over 800hrs on it. When it gets fully warmed up, especially if it痴 hot outside, it is very hard to start. Today, after a couple of hours bush mowing in 30C heat it stalled when I idled it down to disengage the PTO. It would not restart until I opened the throttle almost fully while cranking, after which it very slowly picked up rpm until about the normal idle speed and then quickly picked up from there. Idling it down fully caused it to stop again. After letting it run at a higher idle with no load for a bit I was able to (slowly) idle it all the way down. Once I got it to idle down it is surging at idle. No rough running or other issues I致e noticed. Anyone seen anything else similar before? Thanks, Sam
   / 2010 DK45SE stalls when idled #2
Sounds like a fuel supply issue, checked your filter lately? With the filter off open the valve to the tank and check flow to make sure something is not plugging your line.
Fuel filter was new about 50hrs ago. Hot start issue was present last summer. No loss of power. Will check flow when I next have a chance. Thanks.
   / 2010 DK45SE stalls when idled #4
It sounds a little like when gear teeth in my injection pump broke off but I thought that problem was fixed by 2010. I would look, hard, for some kind of fuel flow obstruction (or air leaking into fuel line) first. Possibly water in the fuel.
   / 2010 DK45SE stalls when idled #5
Def. sounds like supply or just plain old bad fuel.{Bio}
2007 Saturn Sky Convertible Coupe (A55853)
2007 Saturn Sky...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
2016 Chevrolet Sonic LS Hatchback (A53424)
2016 Chevrolet...
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
2015 Cadillac Escalade ESV SUV (A55853)
2015 Cadillac...
