2010 BRANSON 4720h
   / 2010 BRANSON 4720h #1
rasorbackq
Platinum Member
Springfield Nova Scotia Canada
Branson 4720
What rpm on the dash to get 540 at the PTO. And what does this dash mean with the 2 540 PTO ranges?
It has a lever for 540 and down is 780 rpm.
   / 2010 BRANSON 4720h #2
Use the lever at 780 to get 540 at the pto in the 540E rpm range. With the lever set at 540 you will need to run the higher rpm range to get 540 at the pto. The 540E is economy mode.
So are you saying that with the lever in 780 will still get 540 at the PTO in the 540E range on dash?
Want to power a wood chipper .
   / 2010 BRANSON 4720h #4
Correct. That's how I run my brush hog most of the time. Saves a lot of fuel.
   / 2010 BRANSON 4720h #6
Depends on how big the brush is that you are chipping. You can always give it a try. If it bogs tractor down too much you may want to run straight 540. The 540E range is nice for light duty work like pulling a finish mower or light bush-hogging, but if it's going to get a work-out, you should really use 540. IMO there is more damage done to a small diesel engine by bogging it down than by setting it at a comfortable RPM for 540 PTO.
Well I run the chipper in 540E mode for the chipper today . Seemed to work the same only not as loud on the ears from the Diesel screaming at 1700 versus 2400 .
Thanks for the info Huffy2404
   / 2010 BRANSON 4720h #8
No problem. Like jcg said, as long as you aren't bogging down the engine you'll be fine.
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
2021 John Deere R4038 Self Propelled Sprayer (A50657)
2021 John Deere...
4 BRIDGESTONE 11R24.5 (A50854)
4 BRIDGESTONE...
2012 Case IH Patriot 3330 Self Propelled Sprayer (A50657)
2012 Case IH...
2011 GENIE GTH-5519 (A50854)
2011 GENIE...
