200cx tool size
/ 200cx tool size #1
vintagemilano
Cranbrook, BC
JD 2520
Anyone know what size socket I need to retorque the huge nut on the tie bar of the mounting plates for the 200cx. Went around and redid all the others this afternoon and had 4 various nuts that were loose. One of the main pivots that is a greaseable bolt and three of the 18mm bolts on the mounting plates, one on one side two on the other. I do know it's smaller than 32mm though... :)
/ 200cx tool size #2
You could always measure it???, but a lot of the nuts on mine are 24mm.
/ 200cx tool size
It's kinda a crappy location, just figured someone would have been there, done that already. As it's 200'/lbs you would want something that fits right.
/ 200cx tool size #5
30mm.
I also found several loose the first time and had to puchase a torque adapter to reach the one behind the hydraulic pump.
Bad Boy Rogue (A64127)
2006 Hudson Brothers Trailer HTD18D Trailer (A62613)
2006 Hudson...
John Deere 1530 Tractor (A66285)
John Deere 1530...
2022 EZ-GO ELITE...
2000 International 4900 Tandem Truck (A66285)
2000 International...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
