200CX question.
   / 200CX question. #1
Ronster
CT
John Deere 2520, John Deere X739, Kubota U27-4, Kubota RTV 500
I went to the JD web site and pulled up the specs for a 200CX loader on a 2520. It gave a max lift weight of 800lbs at the pivot pin, and 557lbs 500mm form the pivot pin. This spec is with a (v) . Under those specs are another set of loader max weights with an (x) that gives another 200lbs or so to the max weights. I called a JD dealer and he didn't know the difference or the reason behind the v and x weight specs. Anyone know why the two different weight specs for the same loader on the same tractor?
Thanks.
   / 200CX question. #2
The (x) spec is for 1.5m height, 500mm forward of the pivot pin. The boom cylinders lose leverage the higher you lift, so the lift at full height is less.
   / 200CX question.
Thanks!
2019 FORD F-150 (A50854)
2019 FORD F-150...
2014 VOLVO TRUCK VN SERIES (A50854)
2014 VOLVO TRUCK...
2019 Ford F-150 4X4 (A50397)
2019 Ford F-150...
2013 KOMATSU PC490LC-10 EXCAVATOR (A51242)
2013 KOMATSU...
Chevrolet C8500 Flat Bed with a Moffet Kit (A51039)
Chevrolet C8500...
2018 FREIGHTLINER 1085D DUMP TRUCK (A51406)
2018 FREIGHTLINER...
