200cx capabilities on a 2520
   / 200cx capabilities on a 2520 #1
Andy man
Buckley, WA
John Deere 2520
What is the real lift limits of this combo. (properly ballasted) One dealer has spec sheet that says around 800lbs and another at just over 1000lbs. I need real stories and experiences. Pics would be great. FYI I have the 61" bucket and looking at pallet forks.
   / 200cx capabilities on a 2520 #2
straight from deere.com...
MODEL John Deere
200CX on 2520 Tractor
Model 2520
Front Tire 23X8.50 6PR R4
Rear Tire 14-17.5 6PR R4
Wheelbase 65.2-in. (1655 mm)
Pump capacity, gpm 4.96
Rated pressure, psi 2418
Loader
Bucket used ---
Bucket weight, lb. (kg) 183 (83)
Lift capacity at full height, lb. (kg) ---
Measured at pivot (U) 902 (410)
Measured at 500 mm ahead of pivot (V) 629 (286)
Measured at 800 mm ahead of pivot (V) ---
Lift capacity at 59-in. (1.5 m), lb. (kg) ---
Measured at pivot (W) 1124 (511)
Measured at 500 mm ahead of pivot (X) 827 (376)
Measured at 800 mm ahead of pivot (X) ---
Boom Breakout Force, lb. (kg) ---
Measured at pivot (Y) 2239 (1016)
Measured at 500 mm ahead of pivot (Z) 1515 (687)
Measured at 800 mm ahead of pivot (Z) ---
Bucket Rollback Force capacity, lb. (kg) ---
At maximum height (VV) 1596 (724)
At 1.5 m (59-in.) lift height (XX) 1994 (904)
At ground level line (ZZ) 1702 (772)
Dimensions
Maximum lift height, in. (mm) (A) 78.5 (1993)
Clearance ---
At full height - bucket level, in. (mm) (B) 72.2 (1832)
At full height - bucket dumped, in. (mm) (C) 58.5 (1487)
Overall length (I+F), ft. (m) 9.616 (2.932)
Overall height in carry position (J), ft. (m) 3.858 (1.175)
Digging depth, in. (mm) (H) 3.9 (100)
Reach ---
At max. height, in. (mm) (D) 29.5 (750)
At ground level - bucket level, in. (mm) (F) 50.3 (1277)
Bucket Angle ---
Dump angle, degrees (E) 38
Rollback angle, degrees (G) 25
Dump angle, ground ---
Cycle times ---
Loader raise, seconds 3.19
Loader lower, seconds 1.95
Bucket dump, seconds 3.19
Bucket rollback, seconds 1.95
   / 200cx capabilities on a 2520 #3
Andy , the specs are quite conservative. in the real work envornment
the 2520 will lift and do more than what is wrote on paper.
I myself have done things and lifted things , and carried large objects
like machines and logs i did not think it would carry . but it did...;)
I use the Frontier fixed rail pallet forks. and thay work great
Chris......:)
   / 200cx capabilities on a 2520 #4
Andy, I've had my 2520 for a year and a half now, using it in many different projects. I have yet to find the outer limit of it's capabilities yet. The only time I came close was when I was excavating virgin soil made up of heavy clay/wet loamy soil/and watermelon size boulders. I did notice that after hours of use, and the hydraulic fluid heating up, I was not getting full height when lifting a full bucket. I must comment that at this point I think I was past the safe stability point of this size tractor considering the terrain and slope I was working on. Use common sense, the 2520 will measure up to everything you want to accomplish.
   / 200cx capabilities on a 2520 #5
We are all passionate about the machines we use - the good thing is most of us who have (and in just this thread alone) the 2520 have posted pictures on this board that show the machines very conservative capabilities - and then some. If you do a search based on member, you will find them -
Duc
Thanks boys, just put my first hour+ on it. Beats the pants off the 2210-for pulling, pushing and lifting (plus it sounds like a real tractor). Looking forward to using you guys as a resource and picking your brain. :cool:
   / 200cx capabilities on a 2520 #7
Andy man,
Just remember the sales pitch in the 2210 brochure, "this little tractor will move mountains one bucket at a time". I can vouch for the validity of these words. Are the hydraulics quick, no, at least in the mind of those exposed to faster machines. But is there a better value out there? Time will only tell . . .
   / 200cx capabilities on a 2520 #8
629lbs is the honest figure. Thats measured in the bucket, to full height. Its also the figure that New Holland, Kubota and most of the rest of the industry use. It will lift more at lower heights and when the load is closer to the tractor. The dealers who gave you those figures do so to make their product look better. If you put 1000lbs in the bucket and tried to lift it all the way up you'd be very disappointed.
   / 200cx capabilities on a 2520 #9
So far everybody who did hasnt been let down yet - posted pictures doing it on this board - as the doubting thomas that you are with competitive products, sometimes truth, pictures and real world experiences will speak volumes. In this case myself and others have told you so more than a year ago - Kubota B2630/B3030 does not have the hydrolic advantage over the 2520. They have a better tranny, larger backhoe and more PTO power (b3030), but no advantage in lifting ability - I dont spend my time trying to make my machine look better than it is - it does it all by itself :)
My original offer of proving this at some mutually agreeable location still stands - :) :D
   / 200cx capabilities on a 2520 #10
Well Mr bota man , all i can say is you are mistaken.....;)
Chris...:)
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
GRADALL XL4100 IV MOBILE EXCAVATOR (A51406)
GRADALL XL4100 IV...
safety baskets (A53421)
safety baskets...
Honda EU3000is Gasoline Companion Inverter Generators (A54811)
Honda EU3000is...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
