2009 Z920A transmission
   / 2009 Z920A transmission #1
redfin00
Navasota Tx.
5103 John Deere
Changing oil and filters,noticed a leak in left side transmission.Aftre changing leak became worse.Trying to remove transmission,watched a couple utube videos.My model seems to nave a recirculating system,two pipes,deck side going to and from other transmission.These lines apparently need to disconnect to remove transmission.Must be old works that has been deleted?tia
   / 2009 Z920A transmission #2
Sorry I can't help you. Do you have the service manual? That would be a big help.
Richard
No look at getting one.Watched utube videos but none like mine.Watched one where guy takes out both units on same housing.looks like an easier approach.thanks
   / 2009 Z920A transmission #4
I think they can come out as a pair when you remove the crossmember, reservoir etc.
Yes easier to remove both on the crossmember in my opinion.Cleaned up now need to find leak and decide whether to replace other seals will at it. Owner is 16 yo and been a good one!
Found the problem,plastic cracked!Now to get new parts and reassemble.
Electric Horseless Carriage (A57453)
Electric Horseless...
PALLET BOX OF MISC (A58374)
PALLET BOX OF MISC...
2026 Anvil T/A Enclosed Trailer (A56859)
2026 Anvil T/A...
2022 New Holland C327 Compact Track Loader (A56435)
2022 New Holland...
2007 Ford F-750 2,000 Gallon Water Truck (A55973)
2007 Ford F-750...
PALLET TOTE OF CERAMIC TILES (A58374)
PALLET TOTE OF...
