2009 Cub Cadet
   / 2009 Cub Cadet #11
I don't think gas USAGE is the big problem. I do think the SIZE of the tank is the problem.
   / 2009 Cub Cadet #12
The Kohler Command twins all typically burn about one gallon/acre when mowing. That's typical across the board with any gasoline powered machine. As far as scalping goes, some high spots will scalp no matter how the deck is adjusted. If the width of the high spot is less than the wheel base of the deck, it's going to scalp. With the 44", you do need to make sure the deck 'hangs' and doesn't ride the ground. You also want to make sure the deck is very slightly nose down and the gauge wheels are adjusted so they don't bang around on the ground. As far as the trans leak goes, is it on one of the bolts on the vertical split? Some thread sealer would fix it. Sad, but that's probably all the dealer would do.
Joel
   / 2009 Cub Cadet #13
You got that right! Remember when you could put about 5 gallons of gas in the tank? Of course gas was alot cheaper than it is now!
Michael
2019 TerraGator 7300 Spinner truck (A55315)
2019 TerraGator...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2006 Chevrolet Express 3500 Versalift Vantel29N 29ft Bucket Van (A56858)
2006 Chevrolet...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
2017 John Deere 6120E (A53317)
2017 John Deere...
SARLO MOWER (A55758)
