2008 Kioti DK55 has lots of vibration at high speed.
   / 2008 Kioti DK55 has lots of vibration at high speed. #1
daler
metcalfe, on
2008 kioti dk55
I adjusted the toe in to the specs required as the bar holding the tie rods was bent throwing the wheels out. After doing this I figured I would have solved the vibration problem but it still shakes at high speed.
Any help would be appreciated.
   / 2008 Kioti DK55 has lots of vibration at high speed. #2
Check tire pressure. If tires are loaded check for leaks.
   / 2008 Kioti DK55 has lots of vibration at high speed. #3
Welcome to TBN. Did you straighten out bent tie rod? Is it possible that tie rod ends or something else was damaged? I would jack up front end and check each wheel for excessive play. Keep us posted on what you do and find.
   / 2008 Kioti DK55 has lots of vibration at high speed. #4
What was the cause of the bent steering link? Did you possibly damage a tire too? Depending on what happened will hopefully tell the story of what might still be wrong.
Post back and give any additional info- thx, CM
   / 2008 Kioti DK55 has lots of vibration at high speed. #5
I have had the 4x4 not disengage. That will sure make it bounce at high speed.
   / 2008 Kioti DK55 has lots of vibration at high speed. #6
You haven't said how the tierod got bent? And if you swap tires left to right see if that makes any difference. Define 'high speed'.
TUGGER TRAILER (A55745)
TUGGER TRAILER...
2014 PETERBILT 388 VACUUM TRUCK (A55745)
2014 PETERBILT 388...
2017 Ram 1500 SLT Crew Cab Pickup Truck (A56858)
2017 Ram 1500 SLT...
2024 CATERPILLAR 255 SKID STEER (A52707)
2024 CATERPILLAR...
204158 (A57193)
204158 (A57193)
2022 Kubota Z422-54 Zero Turn Mower (A55315)
2022 Kubota...
