2008 Kioti DK55 has lots of vibration at high speed.
   / 2008 Kioti DK55 has lots of vibration at high speed. #1
daler
metcalfe, on
2008 kioti dk55
I adjusted the toe in to the specs required as the bar holding the tie rods was bent throwing the wheels out. After doing this I figured I would have solved the vibration problem but it still shakes at high speed.
Any help would be appreciated.
Thanks
   / 2008 Kioti DK55 has lots of vibration at high speed. #2
Check tire pressure. If tires are loaded check for leaks.
   / 2008 Kioti DK55 has lots of vibration at high speed. #3
Welcome to TBN. Did you straighten out bent tie rod? Is it possible that tie rod ends or something else was damaged? I would jack up front end and check each wheel for excessive play. Keep us posted on what you do and find.
   / 2008 Kioti DK55 has lots of vibration at high speed. #4
What was the cause of the bent steering link? Did you possibly damage a tire too? Depending on what happened will hopefully tell the story of what might still be wrong.
Post back and give any additional info- thx, CM
   / 2008 Kioti DK55 has lots of vibration at high speed. #5
Thanks
I have had the 4x4 not disengage. That will sure make it bounce at high speed.
   / 2008 Kioti DK55 has lots of vibration at high speed. #6
You haven't said how the tierod got bent? And if you swap tires left to right see if that makes any difference. Define 'high speed'.
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2000 Sterling L9513 Winch Truck (A55315)
2000 Sterling...
2024 ArmorLite Aluminum End Dump Trailer (A55315)
2024 ArmorLite...
2015 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A52709)
2015 CATERPILLAR...
2020 CATERPILLAR 299D3 XE SKID STEER (A52709)
2020 CATERPILLAR...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
