2008 Kioti DK 40se left front broken hub assembly
   / 2008 Kioti DK 40se left front broken hub assembly #1
Baranx4
Northeastern, Pa.
I was using my tractor any heard a grinding noise, got off and found gear oil on left front tire was discing in 4wd, noticed outer hub assembly was damaged with the short shft that attaches to the tire assembly hanging out. Pulled it all apart and went to wallace tractor. Rick is a great guy and took care of me. Really went above and beyond. Got me everything I needed from the aluminium outer housing to the snub shaft.
So I put everything together, filled the resevour with gear oil and spun the tires, didn't sound any louder than other side. Started driving it and it ran fine. Put it in 4wd and got about a 1/4 mile and saw gear oil on left front again. Same issue cracked the outer housing again. Only thing I can think of is that the bearing that the housing rides in must have wear and is causing the gear to jump. I am off tomorrow and plan on taking it apart and placing the shaft back in the slow without the outer housing. Dealer hasn't seen another issue like mine, was wondering if anyone else has. The ring gear looks in good shape.
   / 2008 Kioti DK 40se left front broken hub assembly #2
More details, pics, # of hours on tractor, primary use, maintenance intervals and fluids changed by the 'book'?
   / 2008 Kioti DK 40se left front broken hub assembly #3
I also noticed oil on the front r/side yesterday . Mine is a 2006 ck30hst with 815 hours on it, I took it apart and found the seal was bad and ordered parts, To answer your question there is a lock ring that holds the stub shaft in place and if that came off then the shaft will move, I had a wd45 that did exactly that. The parts manual call it a pin but it is a lock ring.
I figured it out. Looks like my initial retaining clip failed. Got lucky second unit wasn't damaged like I thought. Took it apart and was still good. Just waiting for the clips from the dealer now.
Sorry about not posting it sooner
   / 2008 Kioti DK 40se left front broken hub assembly #6
Can a guy get some pics of the situation, at any stage along the route? PLEASE? :)
Thanks,
CM.
2013 FORD F-650 ROUSTABOUT (INOPERABLE) (A52472)
2013 FORD F-650...
2011 Kubota R520S Articulated Wheel Loader (A51691)
2011 Kubota R520S...
PIPE TRAILER (HOMEMADE NON TITLED) 28FT (A52472)
PIPE TRAILER...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A52748)
2018 Dodge Ram...
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
