2008 JD 5303 fuel gauge troubleshooting?
   / 2008 JD 5303 fuel gauge troubleshooting? #11
I have a PDF of the Deere technical manual you're welcome to, if wanted shoot me your email
Joe
Joe
Thank You for the PDF.
Ronnie
Ronnie, it sounds like your fuel sending unit is the issue then. If that's the same as mine, you can find the fuel sending unit, part number RE73915 on Amazon for around $24. I would also get the rubber gasket, if you're going to change the sending unit. That is part number R125590.
As for mine, I went through and tested a bunch of test points, and nothing changed. I even made a direct ground to fuel guage, and a direct fused power,and a sender wire, and my guage still only went to 3/4 so unless those can be calibrated, mine is just going to stay the way it is for now.
   / 2008 JD 5303 fuel gauge troubleshooting? #14
Rob
Thanks for the tip, i'll look into that, like you, i'll probably let it ride myself. I'll fill it this weekend to see what it goes to.
I normally put 6 gallons at a time in for the most part, mow some & add another 6, during the winter months i keep it full, something i was told years ago that helps prevent sweating or moisture:confused3:
Joe, once again, THANKS for the PDF.
Ronnie
TANK SEEDER (A58214)
40' CONTAINER (A52706)
New/Unused Electric 3-Wheeler (A57453)
New/Unused...
2022 Horizon Trailer (A55973)
2022 Horizon...
2019 Ford F-550 (A55973)
2019 Ford F-550...
LOT: Cutters, Shears, Giant Chalk Line, 100' Tape Measure (A59076)
LOT: Cutters...
