2008 JD 4005 Electrical trouble
   / 2008 JD 4005 Electrical trouble #1
rsilva20520
JD4005
Not getting power to S terminal at starter from key switch
   / 2008 JD 4005 Electrical trouble #2
Have you checked all safety interlock switches? Like seat switch, clutch or gear switch, pto switch, etc
Checked seat switch but not the others. Ran out of daylight. Had it running 30 minutes before shut it off.
After the process of elimination checking fuses seat switch, ignition switch, starter, fuel shut off switch, PTO, parking brake switch. Found the parking brake switch had a bad connection
Thanks✌🏽
After 2 days of trouble shooting, testing, and tracing found the culprit. A bad connection in the parking brake switch. It might of been easier if I would of notice in the beginning that the park light on the dash was illuminating. Thanks for all the advice. Out of the deal I purchased 2 manuals I never had. Bought the tractor used with 600 hrs from a vineyard auction
2014 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54313)
2014 FREIGHTLINER...
2008 AAR MOBILITY SYSTEMS REFRIGERATOR CONTAINER (A54607)
2008 AAR MOBILITY...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55301)
GOODYEAR SET OF...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
2016 CAT 325FL CR (A47477)
2016 CAT 325FL CR...
