2008 JD 2320 200CX Loader Question
/ 2008 JD 2320 200CX Loader Question #1
bigj11
Hey Everybody,
I'm thinking about purchasing a used 2008 JD 2320 with a 200cx loader. My only question is if this loader has the quick attach/detach capability? Is there anything I should be worried about purchasing this used tractor? Everything appears clean on the outside, and it only has 80 hours on it. Is there anything I should check out on the tractor before I purchase it from the owner?
Thanks!!!:)
/ 2008 JD 2320 200CX Loader Question #2
You'll totally enjoy the tractor. Yes it's quick release if its the cx200 loader. JD made an x200 loader in that year, that is not quick relese, but I think they are rare as I've never seen one and the saving was only $200ish from new, not worth the saving. Also the bucket is quick attach also. The only down side is Deere uses there own quick attach bucket system which does not match with the skid steer system.
Awesome! Thanks Yelbike!! How is this loader overall, can it curl while being raised? Also, if properly serviced and maintained how many years do you guys think I can get out of this tractor? It will be primarily used for cutting the pastures on my 5 acre horse farm, and occasionally spreading mulch.
/ 2008 JD 2320 200CX Loader Question #4
To curl while raising is a little slow with both the 2305 and 2320. They are both super strong as I have 54" bucket on both and they can both handle a full bucket of lime stone. Just be careful and wear your seat belt as they do roll over.
/ 2008 JD 2320 200CX Loader Question #5
I'm very happy with my 2320 and 200CX. On and off is really only a few minutes. The hydraulic connections take as long as the mechanical attachment.
As noted above, this is a really strong built loader for a tractor the size of the 2320. I've tried to lift/pull things several times that there was not enough lift capacity to move and I couldn't detect any deflection in the loader arms or bucket.
/ 2008 JD 2320 200CX Loader Question #6
Bigj11
My 2320 200cx loader curls and lifts as long as the rpm is over 2800. The loader is slower than a lot of other Deere loaders but I consider that a feature. It helps keep me out of trouble. Strongly recommend a toothbar if it doesn't already have one. That increase digging efficiency a whoop or maybe a whoop and a half.:) Check to see if there is a lot of play in the loader pins; I was told by my dealer that a lot of people have a tendency to not apply enough grease so the pins wear out.
/ 2008 JD 2320 200CX Loader Question #7
Also check the cutting edge of the bucket. With only 80 hours you are not looking for wear, but looking to see if it has been bent. It should be straight.
If it is bent, also look at the loader booms for any tweaks, bends, cracks or repairs (welds). I doubt you will find any problems/abuse, but look before you buy.
/ 2008 JD 2320 200CX Loader Question #8
Also find a level spot and verify that the bucket sits level on the ground. If it isn't than either the rear tire pressure is off or the loader is twisted. Tire pressure is easy to fix, a twisted loader is not.
/ 2008 JD 2320 200CX Loader Question #9
No issues with ours. IMO it's a good tractor.
I would also test drive it with and without 4WD.
Can you let us in on how much money and what you are getting for said money?
The guy wants 13,500 for the 62d mower 200cx loader and 2008 2320. I don't think I'm going to buy this tractor anymore. I priced a new one at a dealer for 16,600 with 0% financing. Do you guys think thats a good price before tax or can I get a little more off? Also, there isn't supposed to be a new 2320 that will replace the current 2320 anytime soon that I should wait to get right?
/ 2008 JD 2320 200CX Loader Question #11
Unfortunately the Deeres hold there value a little too well, I looked around and I found some, but none had the backhoe or the R4 tires I was looking for and the cost was so close to the new tractors, it just didn't make sense.
If you are going new, I would look at the 2520, it has a much stronger hydraulic system that allows the loader to move almost twice as fast and it isn't too many more dollars. In my humble opinion the 2520 is the sweat spot in the 2000 series lineup.
Good luck.
/ 2008 JD 2320 200CX Loader Question #12
As Bethesda posted,Deere's do hold their value,which is like a double edged sword,good for the seller,and bad for the buyer.
No new model (2320) in the future that we know of.
Also,as Bethesda posted,I too would encourage you to get a price comparison between the two (2320,2520),You never know,you just might be able to swing the 2520.:)
Greg
/ 2008 JD 2320 200CX Loader Question #13
I almost bought a 2320 but I did a last minute upgrade to the 2520 right before the purchase. Looking back I am so glad I did, the 2520 is so much more tractor for not much more cash. I just looked at the two quotes, the 2520 was $2500 more, I did 36 month interest free so that works out to about $70 a month.
Thanks guys for all of the responses! Do you really feel that the 2520 is worth it? Will the 2320 really be that disappointing? Im going to primarily use it for moving mulch and mowing. I will rarely be grading/terracing/anything else you do with a loader. Input?
/ 2008 JD 2320 200CX Loader Question #15
IMO, the only thing the 2520 will do better for the home owner is mow large acreage. The 2520 is better equipment for mowing, a little more power/torque (bigger tires) and larger hydraulic flow. Sure the FEL on the 2520 is faster but unless you are using the loader every day, all day, so what and if you do the tractor won't last very long. We got 20 years out of our old JD650 and it was still good to go when we traded it. Again IMO, the 2320 or the 2520 will not make 20 years the way I used the 650 on our 8 acer horse farm/ranch but your not going to buy a tractor today like you could in 1988. In short, both are undoubtedly good tractors.
/ 2008 JD 2320 200CX Loader Question #16
You will not be disappointed with the 2320, it is a very good tractor, but the 2520 definitely has an advantage when doing loader work and the extra weight, bigger tires and little more grunt from the engine certainly help too.
/ 2008 JD 2320 200CX Loader Question #17
Another thing to consider, if a replacement comes out that is alot more $s than the current model, used prices go up.
/ 2008 JD 2320 200CX Loader Question #18
$16.6k sounds a little high to me. Not much but you can get him down a little more. I'd say a little under $16k. I've never priced one out - just from the other Deere I've bought.
Deere has not revealed any plans for a new 2000 series.
/ 2008 JD 2320 200CX Loader Question #19
Prices vary locally, but I think 16.6K is a pretty good deal for a 2320, 62D and 200CX. I paid 18K (before taxes) for the same package plus a power beyond and a box blade 18 months ago. Looks like there's a good discount there.
/ 2008 JD 2320 200CX Loader Question #20
I totally agree!:thumbsup: The 2320 is a great tractor!:thumbsup: It does everything you need. There is alway a model with more options but where does the bleeding stop:(. At least your bleeding the right color!!!:licking:
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
1990 FORD LT9000 HOT OIL TANK TRUCK (A67714)
1990 FORD LT9000...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2006 PETERBILT 379 (A67714)
2006 PETERBILT 379...
2022 CATERPILLAR 259D3 SKID STEER (A65056)
2022 CATERPILLAR...
(INOP) 2006 INTERNATIONAL 7400 DUMP TRUCK (A65054)
(INOP) 2006...
