2008 Foton 254 Generator to Alernator Swap
   / 2008 Foton 254 Generator to Alernator Swap
Your right that the ammeter might be better suited to read battery current evidently bypassing the starter motor. The pulley was changed with a smaller pulley to help at idle.
   / 2008 Foton 254 Generator to Alernator Swap #13
I swear I read about that very modification on this very forum. I wonder if you bought it from a former poster here.
   / 2008 Foton 254 Generator to Alernator Swap #14
I have a Delco 60 wired with the ammeter in the ckt and it's worked fine for years now. I would recommend that when not in use that you put a Battery tender on it. That way when you start it the alternator doesn't have to peak out through the cheap Chinese wiring.
Steve
I'm upgrading the wire of the primary wiring so I think I'll be fine in regards to the wiring. But thanks for your input, it is much appreciated. I might install a battery tender eventually, we'll see :)
   / 2008 Foton 254 Generator to Alernator Swap #16
Hello,
I have a 05 Foton ft404, previous owner lost keys, and ran with out gauges. I was hoping key was only issue, but doesn't look like it. As I found major issues with Chinese Tractors is the electronics, and the external voltage regulator, I want to swap out the alternator I picked up a 80 GM 2 WIRE alternator.
Any further information and guidance would be greatly appreciated. I used a power wheel battery to supply power to the instrument panel, all seemed ok. Trying to figure out how to hook up panel to power with upgraded alternator.
Thanks again for any help
Greatly appreciated
   / 2008 Foton 254 Generator to Alernator Swap #17
Might be better to start a new thread instead of resurecting a 3 year old one...
Few hints thoug. Panel wiring should really be uneffected. That should be guided by the original wiring diagram and should be uneffected by a new alternator installation.
As for the alternator, I would suggest looking at some system/vehicle diagrams that use that alternator to see where the new alternator typiclly returns power to the system. In the end tough, the foton schematic should show one alternator output where it puts power back into the wiring. What can be confusing is that the external regulator probably uses a sense wire where it measures the voltage it is regulating to. This wont be used with the new alternator and can be removed when you pull out the old reg. At any rate the new alternator needs to connect to that old power input point
   / 2008 Foton 254 Generator to Alernator Swap #18
Thanks Ron,
Yeah I figured I'd respond to their old post since they did it. I was thinking just replace the fuse box and wires as they have been part of the Chinese issues.
   / 2008 Foton 254 Generator to Alernator Swap #19
This web site has a lot of good information on auto wiring which is compatible with a tractor,
MadElectrical.com - Electrical Tech
Good connections and components are the key, a lot of people will try and steer you away from crimp connectors,
the good ones designed for outdoors and under water work well. similar to these
Amazon.com: 5pcs Heat Shrink Butt Connectors, Sopoby Waterproof Wire Connectors Insulated Crimp Electrical Terminals Marine Automotive (3Red 2Blue): Cell Phones & Accessories
   / 2008 Foton 254 Generator to Alernator Swap #20
Crimp connectors are fine, IF you use the right crimp tool like a klein 1005 or 1006...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
100 GAL L SHAPED FUEL TANK (A50854)
100 GAL L SHAPED...
2012 KENWORTH T800 (A50854)
2012 KENWORTH T800...
INGERSOLL RAND G40 GENERATOR (A50854)
INGERSOLL RAND G40...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2016 Chevrolet Caprice Sedan (A50324)
2016 Chevrolet...
