2007 toolcat 5600 - how can I tell if it’s high flow?
   / 2007 toolcat 5600 - how can I tell if it’s high flow? #1
s2dm
Carpinteria
Toolcat 5600, Deere 210, Cat 320, Kubota KX080, Kubota KX040, CAT CP433 Compactor, Bobtail dump, cushman truckster
One dealer said it was, one said it wasn’t. Original seller said it was. Just trying to sort what I’ve got.
   / 2007 toolcat 5600 - how can I tell if it’s high flow? #2
It was available on the D Series, so if yours has it there will be a switch to select it or a separate connector to plug the high flow hose into.
A switch on the dash? Just so I understand, a high flow machine would have a regular flow on off switch and then a high flow on off switch?
   / 2007 toolcat 5600 - how can I tell if it’s high flow? #4
Just one switch.
   / 2007 toolcat 5600 - how can I tell if it’s high flow? #5
On the center console labeled "High Flow".
Picture from a 2010 D Series:
Should I assume no hi flow despite the 3 hydraulic lines up front?
   / 2007 toolcat 5600 - how can I tell if it’s high flow? #8
That is what I'm thinking. I looked at older std. flow Toolcats online and they too seem to have the 3 lines up front.
   / 2007 toolcat 5600 - how can I tell if it’s high flow? #9
Right, the small center line is case drain.
   / 2007 toolcat 5600 - how can I tell if it’s high flow? #10
It's a common misconception that the presence of a case drain connection indicates a High Flow machine. It has nothing to do with high flow vs standard flow. All Toolcats have the 3 aux hydraulic lines, even in '02-03 when high flow wasn't available as an option.
Another thing to be aware of is that high flow vs standard flow is really only relevant when talking about the same machine. Standard flow on some skid loaders has a higher flow rate than high flow on a Toolcat.
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
2000 INTERNATIONAL 9200 (A58214)
2000 INTERNATIONAL...
2012 PETERBILT 388 (A58214)
2012 PETERBILT 388...
(INOP) RHINO 1310 ROTARY CUTTER (A52708)
(INOP) RHINO 1310...
PALLET OF ROUND & SQUARE STOCK (A52708)
PALLET OF ROUND &...
2018 Ford F-150 XLT Sport Pickup Truck, VIN: 1FTEW1EP6JFD27162, Crew Cab, 4 x 4, 2.7 L EcoBoost Gas (A59076)
2018 Ford F-150...
