2007 Kawasaki Mule 610 issue
   / 2007 Kawasaki Mule 610 issue #1
Roadbuilder6
VT/Ct
Farmall m, Kubota, deere z655
Hey guys. Yesterday I was driving our 2007 Kawasaki Mule 610 home, from plowing a neighbors. I was driving down a not so steep hill and heard a loud pop. All of a sudden I lost all power and even though the gas pedal stayed in the same position, the engine started idling and pulled back. I let off the gas and got power again, kept going and it happened again, did the same thing because I was on a tight corner and didn't want to stop and it happened again, so I limped to a good area and turned it off. I lifted up the seat and there was a cap with fuel lines going into and out of it, and a liquid, brown, very vicious with bubbles was boiling out. It smelled like gas. I ended up towing it home. I should add it was about 1 degree Fahrenheit at the time. I started it again when it was warmer and did get it started but it did the same thing and was hard to limp it into the barn. I am not sure what the issue is. I will attach a picture with where the gas was boiling out of. Any advice or knowledge is greatly appreciated, Thanks, John
The part, not sure if there was a cap or cover for it?
   / 2007 Kawasaki Mule 610 issue #2
Not sure what's going on with it but that's your fuel pump.
Is the housing cracked or where is the fuel coming from?
2013 Ford Taurus Sedan (A55853)
2013 Ford Taurus...
UNUSED I/A R2228X 12' TANDEM DISC HARROW (A57192)
UNUSED I/A R2228X...
Tandem Axle Rear Truck Frame (A55852)
Tandem Axle Rear...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
WOLVERINE TF3-66-2600G PIN ON PALLET FORKS (A57192)
WOLVERINE...
2004 950M Towable Cement Mixer (A55851)
2004 950M Towable...
