2006 Toolcat C Rear Steering Hydraulic Leak and Wandering Out of Alignment
   / 2006 Toolcat C Rear Steering Hydraulic Leak and Wandering Out of Alignment #1
Freeze Plug
Canton, CT
2006 Bobcat Toolcat 5600 C
My 2006 Toolcat C has developed a hydraulic leak, it looks like it is coming from the rear hydraulic steering ram. Even when not in 4 wheel steer, when a rear wheel contacts something such as a rock or a rut that can bump it out of place, the rear wheels start tracking off and I need to go into 4 wheel steer to correct it. It will usually wander off again shortly after, even in 2 wheel steer. External forces seem to move them out of alignment easily.
Can a simple leak cause such erratic behavior, and can anyone give me a rundown of what I am in for to reseal this? I have to get it into the shop this week to get a better look but am looking for advice ahead of time to prepare myself
Thanks!
Austin
I ordered a seal kit. It appears to be leaking from the seals between the axle housing and power steering ram housing, not the actual seals between the shaft and housing. Has anyone had to do this repair? The bobcat manual goes into very little detail
Looks like I am going to need to split the rear axle housing, can anyone confirm that this is the case? I REALLY don't want to split the housing
   / 2006 Toolcat C Rear Steering Hydraulic Leak and Wandering Out of Alignment #4
I hope you get the answers and help you need on your C series.
I cheaped out. I didn't want to waste time pulling and splitting the axle, so I compromised. I 3D printed two half moon shaped snap on sleeves using the length of the centered steering ram from the manual (90mm driver's side and 150mm passenger side). The printers at work use a material that consists of nylon impregnated with pulverized carbon fiber, and is extremely strong. These sleeves clip onto the exposed ram shafts on either side of the ram hosing, locking the rear steering ram in place. Then I looped the hydraulic lines with a junction, and used AN fittings to plug the axle ports
So now I have no 4 wheel steering, but it only took an hour and $30 to fix. I can live with that for now, and when the time is right, it is completely reversible when I have more time to complete the repair in full
here are a few crappy pictures
   / 2006 Toolcat C Rear Steering Hydraulic Leak and Wandering Out of Alignment #7
Very interesting and thanks for the pictures.
2021 KENWORTH T270 (A55745)
2021 KENWORTH T270...
Giyi 59" Log Splitter (A53316)
Giyi 59" Log...
30pc 3ft. x 8ft. Red Polycarbonate panels (A55758)
30pc 3ft. x 8ft...
2015 Takeuchi TL8 Compact Track Loader Skid Steer (A55787)
2015 Takeuchi TL8...
2002 Ford F-450 Lift-All LAH-30-15 30ft Bucket Truck (A55788)
2002 Ford F-450...
CFG Industrial MX15RX (A53316)
CFG Industrial...
