2006 RTV900 Transmission won’t engage
   / 2006 RTV900 Transmission won’t engage #1
KYBluegrass
Kubota RTV 900
New member trying to help out my elderly neighbors that have a 2006 Kubota RTV900. Used just to bring feed and supplies back and forth to their barn down the street. He had a family member change the oil and overfilled the engine by googling and finding the wrong answer. Filled up and started overfilled, ended up seizing the starter and started smoking. I undid battery, replaced starter and engine fired, blew some smoke and now runs ok.
Thought we were done and now the UTV won’t engage the transmission. Can shift to any gear easily and locks into position but given gas it just revs and doesn’t move. I can manually push it into and out of the garage in any gear with brake released. I pulled and checked the gear change mechanism on top of the transmission and forks are aligned, everything moving smooth.
Has anyone encountered this and was able to diagnose and fix without taking the entire hydrostatic and transmission off the engine? Trying to help and save them money plus the local Kubota dealer is a 4 week wait just to get in right now. Appreciate the help.
   / 2006 RTV900 Transmission won’t engage #2
First thing to check is the rear axle nuts. If the nut(s) got loose and the splines in the hub were stripped, the axle will just spin in the hub. It is easy to see the axles turning from the back too. That is the easy fix..............
   / 2006 RTV900 Transmission won’t engage #3
Welcome to TBN!
Did the family member change the transmission filter/oil? Oil level in transmission correct?
   / 2006 RTV900 Transmission won’t engage #4
Welcome to TBN!
^^^yes! Being that the family member may have filled the engine to the top of the valve cover, we would have to wonder about EVERY possibility imaginable.
Well you guys nailed it. I believed him when he said that nothing else had been touched. Didn’t check the simplest fix 🤦‍♂️
He must have messed with the transmission as well because I pulled a filter and it was empty. So checked fluid and really, really low. Feel dumb now but hope this helps someone in the future. Filters were Amazon special so off to Kubota dealer and bought filters, transmission fluid and rest of filters (fuel/air). Dumped transmission, installed everything and she’ll move now. Going to get the bed back on and drive it around in the morning.
Thanks for the quick replies!
   / 2006 RTV900 Transmission won’t engage #6
Great to hear. As a service manager, the dumb question has to be asked as sometimes it is not even suspected!
2024 Kubota L3302 4x4 Tractor with Backhoe (A51573)
2024 Kubota L3302...
2019 Chevrolet Tahoe LT SUV (A51694)
2019 Chevrolet...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2016 Hino 258 Roll Back (A52384)
2016 Hino 258 Roll...
KUBOTA ZD1211 (A53084)
