2006 Lk3054xs, 573 hours, loose shifter. Stuck in fourth gear.
   / 2006 Lk3054xs, 573 hours, loose shifter. Stuck in fourth gear. #1
huffabub
Kioti LK3054XS
Hello, hoping someone can help me out a bit. Was spreading some stone this weekend and was switching between 1st and 4th gear when I would grab a fresh bucket. On the last scoop the shift handle went sloppy and I could no longer shift out of 4th. The shift lever could be lifted up about 4 inches and exposed a tapped thru hole that appears the have come undone. It looks like the shift assembly needs to be separated from the side of the transmission. In order to do that it looks like the floor pan needs to be removed. I have seen a few posts on the subject, but am a bit hesitant to dive in without understanding what I am going to get into regarding realigning forks to reassemble. Any guidance or tips would be greatly appreciated. Thank you.
   / 2006 Lk3054xs, 573 hours, loose shifter. Stuck in fourth gear. #2
Thank you very much
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A53422)
2012 Dodge Ram...
SHOP FAN WELDING CART (3) JACK STANDS (A54757)
SHOP FAN WELDING...
More info coming soon! (A50322)
More info coming...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A57024)
2016 KBH...
2001 Ford Ranger Pickup Truck (A51694)
2001 Ford Ranger...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
