2006 Kubota B26 will not start
   / 2006 Kubota B26 will not start #1
B26
Monterey, TN
Kubota B26 TLB
Long story and will try to make it short. At first my 2006 B26 would start and than 2-5 minutes later die. I by passed the the seat switch about 6 months ago and had no problems. Yesterday it did it again. I started diagnosing with voltmeter in hand. I ordered a new switch last night. Today I went out to look further and found no voltage at the switch and no lights on my dash (glow plug, etc) and my fuel gauge is not reading. Nothing!! I'm going backwards!! At least yesterday these worked!! No relay clicks. I checked all the fuses and relays and all are ok. Battery is good (I even jumped it), No power to the little wire at the starter. My concern now is that even when I get the new switch in it won't do any good as the "B" wire at the ignition switch is now dead. I cant even move it due to the bucket is down! Any ideas??? THANKS!
   / 2006 Kubota B26 will not start #2
clean all your wire connections battery, ground etc
willy
   / 2006 Kubota B26 will not start #3
Good Evening B,
I agree with Willy, sounds like you have a bad battery connection or connections somewhere ! That would be the first things I would do !
   / 2006 Kubota B26 will not start #4
Check the ground and slowly check wires for rodent chewing...let us know your findings.
   / 2006 Kubota B26 will not start #5
Clean and check your fuses. On the B20 there is a high amp fuse near the starter. Looks like a loop of wire with a connector. Usually wire tied to the wiring bundle. Had this unusual fuse blow after decades of use. Think my newer kubota tractors have the same thing.
All for safety and improvements. Don’t like when safety switches malfunction shuts down the tractor usually at the worst time and furtherest from the shop. Need a “combat” master override switch. Sometimes I need to stand to see to operate safely.
   / 2006 Kubota B26 will not start #6
HST pedal and pto have switches that will not allow the engine to start if not in neutral.
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
HarbinGer V3 Plus Towable Light Tower (A52377)
HarbinGer V3 Plus...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A55301)
2012 NEW HOLLAND...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
2008 KALMER 4X2 SPOTTER TRUCK (A54756)
2008 KALMER 4X2...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
