2006 GT 2544 Kohler Command 21 - Synthetic oil??
   / 2006 GT 2544 Kohler Command 21 - Synthetic oil?? #1
wfapple
New to Cub Cadet & board. What is the feeling about putting synthetic oil in the engine after the first 25 hour break-in? Manual seems to only say acceptable up to 40 degrees F but everyone tells me I should go synthetic especially on air cooled engine. Thanks, I want to get the best life out of my Kohler.
   / 2006 GT 2544 Kohler Command 21 - Synthetic oil?? #2
Go for it. Letting the engine break-in on the factory oil then switching to synthetic is the way to go. Having said that... synthetic or not... the engine will probably be the last thing to go!
Have fun.
   / 2006 GT 2544 Kohler Command 21 - Synthetic oil?? #3
do it up brother....feed the beast synthetic.
   / 2006 GT 2544 Kohler Command 21 - Synthetic oil?? #4
Going to synthetic @ the first oil change is perfectly fine. I just did my pre season oil change on my kohler command 20 & used Shell Rotella-T heavy-duty synth. 5w-40. I had a cpl qts leftover from a truck I had. I know it goes against the kohler 10w-30 spec, but she runs as smooth as butta on it. No way I was going to let a good oil collect dust on the shelf!
Joel
   / 2006 GT 2544 Kohler Command 21 - Synthetic oil?? #5
Totally agreed, especially as these small air cooled engines don't hold that much oil, the extra cost of synthetic makes it not so prohibitive for the viscosity stability advantage of synthetic oil. Remember though, synthetic oil DOES NOT extend oil change intervals. In other words disregard that advertising hype they are using as a selling point for putting it in your car for that purpose. Using it can and may extend engine life, but it is not an excuse to change the oil less frequently. Many newer OHV small engines such as Kohler Commands and Courage, Briggs and Stratton, Honda, Kawasaki, etc, have hydraulic valve lifters and using synthetic oil in these can have a major advantage with reducing wear on cold engine stratups.
I don't recommend synthetic oil for older or more worn small engines. Why? Synthetic oil tends to be more leak-prone than the dinosaur oil older engines are made to run on. It can turn a small seal leak into a big one, or make new leaks that didn't exist before.
-Fordlords-
2017 Ford F-250 Enclosed Service Truck (A53422)
2017 Ford F-250...
8ft Fork Extensions (A55851)
8ft Fork...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A57024)
2018 John Deere...
2011 Chevrolet Equinox SUV (A53424)
2011 Chevrolet...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A55851)
2019 Caterpillar...
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab 9FT Flatbed Truck (A51692)
2018 Chevrolet...
