2006 Ford New Holland TC45DA will not start
   / 2006 Ford New Holland TC45DA will not start #1
riclau
Harrington, DE 19952
ford
Hi I have a 2006 ford new Holland TC45DA and had some problems starting before with high/low gear- Now it wont start at all. .. does anyone Know why
   / 2006 Ford New Holland TC45DA will not start #2
Is it turning over?
thank-you for your time. No turn over. just a click noise
I jumped starter no turn over. battery tested good too
wrong info I jumped starter and will crank- Sorry
   / 2006 Ford New Holland TC45DA will not start #7
Have you checked the fuses behind the gauge panel?
If you have, remove the plug from the fuel shutoff solenoid and unscrew it. If it starts it's a bad solenoid. As a heads up, you have to reinstall the solenoid to shut it off.
can you tell me ware its at- fuse at low floor board ok
   / 2006 Ford New Holland TC45DA will not start #9
On the right side of the tractor you'll see the injector pump. The fuel shutoff solenoid screws into the left side of the pump. It's cylindrical and has a wire / spade connector plugged into the end of it. You can gently use a pair of channel locks to get it loose. If it doesn't start with it removed, plug the spade connector back in before reinstalling the solenoid and turn the key on and off to check operation. The plunger should move in and out.
I should mention that the solenoid can be hard to see without a flashlight even during the daytime.
Thank-you soo much I did see a turn knob at where your saying
2016 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A55973)
2016 Chevrolet...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
Bucket (A55973)
Bucket (A55973)
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2013 Ford F-150 Pickup Truck (A56858)
2013 Ford F-150...
SCALES & PEA (A58374)
