2005 tn75da radio harness help
   / 2005 tn75da radio harness help #1
Tn 75 da wired for factory radio want to get a harness to hook upi a after market radio. Does any one know were and what kind of harness i need so i dont have to cut the wires? Thanks
   / 2005 tn75da radio harness help #2
New Holland dealership. It should cost you $20.- $30 dollars depending how high they went up.
Thanks but went that route. All dealer i called dont know what is needed? All they want to do is sell me a radio for 300$. or have me cut the harness off.
   / 2005 tn75da radio harness help #4
Go at it from the other end. Get the radio manufacturer to supply the correct adapter harness for your tractor. Almost all Nh and CIH tractors use the same adapter harness with different pins used for keyed and constant power.
   / 2005 tn75da radio harness help #5
On my TN, I just took the harness that came with the radio and cut the harness in the cab and spliced it in. Took about 20 minutes with a VOM to identify wires.
Andy
2015 Nissan Frontier S Crew Cab Pickup Truck (A50323)
2015 Nissan...
County Line 3 pt 5' Box Blade (A50515)
County Line 3 pt...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
1997 John Deere 8100 MFWD Tractor (A52128)
1997 John Deere...
2010 Nissan Rogue SUV (A50324)
2010 Nissan Rogue...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
